Author: Subject: Bent chassis
LBMEFM
posted on 10/7/17 at 03:12 PM Reply With Quote
Bent chassis
Following a shunt to my n/s/front wheel of my MK Indy it has put a slight bend in the upright square section of the chassis where the round bar is attached that comes up from the lower part of the chassis and the rear of the upper wishbone mounting is. Is the only option to weld in a new upright section?
posted on 10/7/17 at 03:51 PM Reply With Quote
I'd have thought a check on the chassis wishbone pick-ups to make sure there's no distortion would help. Worst case a rebuild with a new chassis, otherwise cut out and replace the bent section as you suggest.
myke pocock
posted on 10/7/17 at 06:14 PM Reply With Quote
Cut out and replace, no question about it.
Ben_Copeland
posted on 10/7/17 at 07:26 PM Reply With Quote
Yep cut it out replace. Pretty easy tbh.
Ben
Locost Map on Google Maps
Enter Your Details Here
LBMEFM
posted on 11/7/17 at 02:08 PM Reply With Quote
Thanks guys, it's stripped and ready to be welded in, as said pretty easy. How are you Ben long time no hear from you?
Ben_Copeland
posted on 11/7/17 at 02:13 PM Reply With Quote
Good thanks mate, If you have any issues give me a shout ! I've got a decent MIG welder.
Ben
LBMEFM
posted on 11/7/17 at 06:35 PM Reply With Quote
Thanks for that Ben but I have got a mate who's a fabricator doing it for me. Look after yourself, all the best Barry.
