Author: Subject: Battery Amps
craigdiver
posted on 12/7/17 at 06:13 PM Reply With Quote
Battery Amps
The battery out my donor BMW 523i was big, 65Ah capacity and 680A cranking power.
Do I really need 680A to crank the 2.5 6-cylinder engine or was this likely to have been rated to run the extensive BMW electrics.
Not looking for expensive lithium based battery just a smaller lead-acid, anybody up on auto electrics that can suggest capacity and power for my haynes roadster?
Craig
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
posted on 12/7/17 at 07:00 PM Reply With Quote
Craig
The std battery listed for your engine is short coded 110 --- which is a whacking great 80ah 800cca sae
If the car is a manual transmission and used only in summer you should get away with a good quality (ie Exide Blue or Varta/Bosch Silver) short code 063 but it will shorten the life of the battery. So treat it kindly and keep it topped up.
CCA isn't really anything to do with normal starting is is all to do with the current the battery can produce for a given time in extreme sub-zero condition before dropping below 7 volts. There are different standards for CCA and the better bsattery manufacturers are always very conservative about the ratings they publish so it is not a really useful bench mark.
Tayna Batteries Link type code 063
craigdiver
posted on 12/7/17 at 07:05 PM Reply With Quote
Craig
Great answer, thank you very much AND I like the look of the prices for the 063 batteries, I'll take your advice and go for the Bosch Silver.
posted on 12/7/17 at 07:33 PM Reply With Quote
Battery is for starting the engine, after that the alternator should generate the electricity to run the electrical gubbins.
Nickp
posted on 12/7/17 at 08:15 PM Reply With Quote
Job done, save weight
Xtreme Racing Dry Cell AGM Battery Motorcycle Rally XR600 alternative to PC680
craigdiver
posted on 12/7/17 at 08:26 PM Reply With Quote
Sold!, 6kg vs 12kg for a 063 lead acid battery.
posted on 13/7/17 at 11:03 AM Reply With Quote
There is a rough formula for guestimating the cranking time you get from a new fully charged battery in mild weather
Cranking time in minutes = (ah*30)/(actual average cranking current)
Keep in mind the AH capacity of a battery reduces with age. How much of reduction not only depends on the age of the battery but the number and depth of discharge-charge cyles it has been subject to.
A 4 year old battery may pass a voltage drop test but have only 1/4 the ah capacity it left the factory with.
A year old battery that hasn't been abused will normally have about 85 percent of its rated ah capacity.
[Edited on 13/7/17 by britishtrident]
coyoteboy
posted on 13/7/17 at 12:43 PM Reply With Quote
And for carrying the load when your engine is off and the kids are sat for 20 minutes listening to the radio, or you need to leave it with the sidelights on for an hour and BMW used 400W sidelights etc etc, and then still have it start.
