Author: Subject: Accusump/ baffled sump
Tartanpimpernel
posted on 12/7/17 at 10:54 PM Reply With Quote
Looking to try a accusump & baffled sump setup on my megablade
DaxRushMLA
posted on 13/4/18 at 12:40 PM Reply With Quote
accusump
Did you ever go ahead with this? Im just installing both on mine next week.
Brendon
Tartanpimpernel
posted on 13/4/18 at 04:14 PM Reply With Quote
Unfortunately not as have been out the country until recently with work, so car has been tucked away.
good luck with the install, be interested to know your results
mark chandler
posted on 13/4/18 at 07:02 PM Reply With Quote
Early blade engine in my car, pull out the bung that the oil pressure sender goes into, drill out the bung weld a 1/2" BSP male threaded end on the bung and you can now connect the accusump sump hose on to this.
DaxRushMLA
posted on 14/4/18 at 07:13 AM Reply With Quote
accusump
Mark,
Any chance you can send me some photos please? (z_bren@hotmail.com or here) mine is from a 98 carburator. I think on the blackbird we only have a pressure loom switch. My engine is stripped off atm, as I blew a bearing and my new engine is arriving this week from the UK. The Accu-sump is a safety precaution Im gonna instal.
What I was going to do is 'T' off from the oil cooler straight into the engine block via inlet using a non return valve also.
What do you think?
Regards Brendon
DaxRushMLA
posted on 17/4/18 at 06:43 AM Reply With Quote
Guys,
If anyone has an Accusump electrical switch for sale please let me know as Im looking to buy one.
+356 99837389
Regards
Brendon
