Tilton 75 Series Brake or Clutch Master Cylinder Kit
Hi All as title Master cylinder,
this is as new and has only been fitted to my car for 2 weeks. I am changing to a cable clutch on my car.
the sales bit and spec is below
£60 including postage in UK.
Tilton 75 series master cylinder in your choice of bore size (please specify your requirements with your order)
75-Series master cylinders are designed for applications where space limitations require a compact master cylinder. 75-Series master cylinders are
61mm shorter than 74-Series master cylinders, but maintain 28mm of stroke. Universal Kit Includes: Master cylinder, 114ml and 193ml reservoirs (with
filters and clamps),remote reservoir mounting components and fittings.
Features
• Reliable seal/piston design.
• High pressure die-cast aluminium body provides a machined-look finish.
• 28mm of stroke provides the fluid displacement needed for a wide variety of applications.
• Industry standard 2.25" (center-to-center) front flange mount.
• Industry standard 5/16-24 UNF Pushrod
Supplied as kit complete with 114ml and 193ml reservoirs (with filters and clamps), remote reservoir mounting components and fittings.
