Author: Subject: Pinto Head with Newman Cam
posted on 14/7/17 at 10:12 AM Reply With Quote
Pinto Cylinder Head ( not unleaded) fitted with a Newman fast road camshaft, Newman long pad cam followers with carbide inserts and Vernier timing pulley. There is no wear visible on the lobes or followers. 200
Pinto Cylinder head for refurbishment. 20
Pinto Rocker covers (x2) 10 each
Pinto Rocker cover with filler spout removed from top and rewelded on front. Allows bonnet to fit properly (well it did on my Avon) 15 (very small oil seapage through a pinhole in the weld, could easily be welded up but never really caused a problem)
Stainless steel inlet manifold for bike carbs on pinto head. Pipes are 38mm dia and are straight 60
Also got a distributor body which I blanked off and fitted to the pinto when I converted to megajolt. I'm sure there's other ways to do this but it worked fine. 5
Quite a few other pinto bits, water pump, various pulleys, etc if you're after anything get in touch I might have it.
Prefer collection (of heavy items)from Ripley in Derbyshire
posted on 17/7/17 at 08:49 AM Reply With Quote
Hi there, do you still have any of the above available?
posted on 17/7/17 at 10:02 AM Reply With Quote
Yes mate what you interested in?
