Author: Subject: Steering column length
starterman
posted on 16/7/17 at 06:08 PM Reply With Quote
Would anyone be able to measure the distance from the two mounting brackets to the steering wheel end of the standard Sierra column please?
Mike
avagolen
posted on 17/7/17 at 06:07 PM Reply With Quote
I have measured one in the garage, unfortunately it has no wheel on it and the spring
is giving a wrong dimension.
Hopefully you can glean enough info from the pictures.
steering shaft_1
steering shaft_1
steeringshaft_2
steeringshaft_2
steeringshaft_3
steeringshaft_3
starterman
posted on 17/7/17 at 06:10 PM Reply With Quote
I think I can get all the info needed from your pictures.
Thank you. That was very good of you.
avagolen
posted on 17/7/17 at 06:33 PM Reply With Quote
No problem.
If I can help further, just ask.
