Author: Subject: Harness Extension
K19
posted on 17/7/17 at 03:51 PM Reply With Quote
Harness Extension
Having a bit of an issue with my harness, the harness mounts are quite far back on the roll car (back supports), which means the shoulder straps are a basically a bit short.
I've heard of a few people making an extension out of 5mm steel, i.e just bolting a long bit of steel on roll bar thats 10cm long that will rotate on the bolt, and attaching the harness to that. Also a few people have mentioned that I could use a saloon harness as they are normally longer, but that requires buying a new harness!
Is there a better solution? e.g a small length of harness with a connector that I can add on? Can't find anything of the sort by searching the internet
Thanks again for any help/advice
I have no idea what I'm doing.
gremlin1234
posted on 17/7/17 at 07:04 PM Reply With Quote
flippant answer, go on a diet ?
K19
posted on 17/7/17 at 11:01 PM Reply With Quote
Hahahaha. The harness fits fine for me, as I have the seat all the way back, but anyone less than 6 foot isn't going to have a good fitting harness!
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 18/7/17 at 08:25 AM Reply With Quote
If the roll hoop is MSA standard, don't weld anything to it. It will be o.k to weld an extension to material welded to it but do not bolt it on. You can then bolt the belts to it as it will be part of the frame and not an extension....You cannot join pieces of belt together and be MSA compliant......
loggyboy
posted on 18/7/17 at 09:43 AM Reply With Quote
There's no reason you cant weld to an MSA compliant cage, providing it isn't removing material or weakening the structure.
Mistral Motorsport
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 18/7/17 at 10:42 AM Reply With Quote
If the main hoop is modified to anything other than the ROPS certificate it will fail scrutineering, However, you can weld to the structure inside it . All the roll hoops that have had extensions welded on top are being failed and certainly don't drill into it.
loggyboy
posted on 18/7/17 at 10:49 AM Reply With Quote
You confusing Homologated cages with those built to the specs laid out in Part K. Its only Homologated cages that have certificates and cant be modified, and they are few and far between. The only Locost that has one i'm aware of is the Procomp LA locost.
Mistral Motorsport
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 18/7/17 at 11:25 AM Reply With Quote
I have just gone through all this with my car, but if you say different, well so be it...
Mr Whippy
posted on 18/7/17 at 11:34 AM Reply With Quote
does the OP actually mention anything about race certification requirements? I don't think so....
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 18/7/17 at 12:38 PM Reply With Quote
I mentioned all that because I am aware that owners of these car do take part in sprints and hill climbs, which are subject to BB rules. It would be a shame if he did the mods and if and when he entered a meeting, or anyone else reading this thread, and found it wasn't acceptable........
Angel Acevedo
posted on 18/7/17 at 02:31 PM Reply With Quote
In a Cessna 152 Aerobat, the harness is anchored to the airframe with Cable Extensions.
Can you use that concept/Idea?
HTH
AA
See link, it´s about mid page...
http://www.unterman-aviation.com/aircraft/1979CessnaAerobat.php
[Edited on 7/18/2017 by Angel Acevedo]
