ttalps2000
posted on 31/7/17 at 07:27 AM |
Zetec Sump
Just starting to organise putting a Zetec into my Stylus due to IVA issues.
One of the hurdles to overcome is the sump on the Zetec engines. How far do they actually protrude down? I'm not running the car stupidly low to
the ground. I'm at approx. 220mm to the bottom of the front chassis member. Do I really need to cut the sump down?!
loggyboy
posted on 31/7/17 at 07:33 AM |
your sump sits 220mm below the chassis?
Mistral Motorsport
ttalps2000
posted on 31/7/17 at 07:53 AM |
no, that's the distance from the floor to the bottom of my chassis rail.
Ugg10
posted on 31/7/17 at 08:19 AM |
Depends on what Zetec you are running -
The silver top (one part sump) 1.8l is shallower (more ground clearance) than the 2.0l and is a straight bolt on (remembering to get the pick up pipe)
and IIRC the CVH sump is also a fit but others will confirm no doubt.
Not sure about blacktops as they have 2 part sumps IIRC.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
ttalps2000
posted on 31/7/17 at 08:36 AM |
It is a 1.8 silvertop. The sump that I have currently available for it is a aluminium version...
Shooter63
posted on 31/7/17 at 08:36 PM |
Send it to dunnell or scholar, they will shorten it and the pick up pipe, no more worries.
Shooter
Angel Acevedo
posted on 1/8/17 at 12:02 AM |
Don´t know about the Zetec sump, but 220 mm is plenty high.
How much protrudes below the fame will depend on your Engine mounts arrangement.
And, even if you have a couple of inches below the chassis, at that ride height, you may be OK with a Skid plate.
I would think that Skid plate would be cheaper than modifying the sump.
ttalps2000
posted on 1/8/17 at 07:21 AM |
Dunnell etc charge a small fortune for doing the sumps!
Have now found a solution to getting it shortened for a few beers tokens if required
Shooter63
posted on 1/8/17 at 07:51 PM |
I'm glad you got the sump sorted out, just remember to shorten the pick up and weld baffles in as well, I've got to say that the
measurement of 220mm to the underside of the chassis rail is massive, are you going to off road😆
My stylus is set at 125mm and that isn't considered that low.
Shooter
ttalps2000
posted on 1/8/17 at 08:26 PM |
may well be 120mm then :s
