New Topic New Reply
Author: Subject: Battery cut off switch and Clock
pekwah1
posted on 4/8/17 at 03:04 PM Reply With Quote
Hi Guys,
I have a digital dash in the kit, and also want to fit a battery isolator.
The only thing i'm thinking is that the dash needs a permanent battery feed for the clock, otherwise it will reset to 12:00 each time.
The only obvious thing i can think is to run a separate perm from the battery side of the isolator to the dash unless someone has a more elegant solution?
Regards,
theconrodkid
posted on 4/8/17 at 03:35 PM Reply With Quote
did that on mine,bridged the switch with a 1 amp inline fuse.
who cares who wins
pass the pork pies
tims31
posted on 4/8/17 at 03:47 PM Reply With Quote
Originally posted by pekwah1
Hi Guys,
Regards,
Also what ECU are you running, if you are using a standard Ford ecu then disconnecting the power will reset that too and I believe that learns over time of how it is being driven and adjusts accordingly.
Build: http://www.martinsfurybuild.co.uk/
pekwah1
posted on 4/8/17 at 03:56 PM Reply With Quote
it is a ford ECU, i was thinking the same thing that i might need to keep that alive as well....
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 4/8/17 at 08:42 PM Reply With Quote
Just a couple of inches of cable between the terminals with a fuse fitted as Conrod says, anyone tries to start it will pop the fuse.
You won't be disconnecting anything
New Topic New Reply
