Author: Subject: st170 engine mounts
rayward
posted on 8/8/17 at 06:43 PM Reply With Quote
st170 engine mounts
does anyone know if the engine mounting holes on an st170 engine are the same as a standard zetec ?
cheers
Ray
big_wasa
posted on 8/8/17 at 07:02 PM Reply With Quote
For a kitcar i.e. On the block they are the same as a Blacktop. To go back in a focus then no. The mounting bolts on the front cover are wider to clear the vvt pulley.
chris
posted on 8/8/17 at 07:09 PM Reply With Quote
one side is the same as the zetec the other is in a different position its the nearside that is different the only bolt hole are further to the front of the engine
[Edited on 8/8/17 by chris]
rayward
posted on 8/8/17 at 07:23 PM Reply With Quote
thanks for the info , its to go in a kitcar yes , so if i buy pre cut plates for a zetec the bolt holes will match , nice one
Ray
chris
posted on 8/8/17 at 07:26 PM Reply With Quote
no they wont off side will the nearside will not its a different bolt pattern
this is my st170 nearside bolt pattern
https://s1.postimg.org/ce0yn5eh9/DSC_0177_7857_st_engine_mount.jpg
this is my blacktop zetec nearside mount the bolt pattern is different
https://s1.postimg.org/4vfo5rh3j/DSC_0154_7737_engine_mount.jpg
the blacktop zetec mounts are from retro ford the diy mounts they sell so the mount plates are pre cut and drilled so you just well the rest suit
big_wasa
posted on 8/8/17 at 07:30 PM Reply With Quote
one side is slightly differant to the silvertop but not the Blacktop.
chris
posted on 8/8/17 at 08:42 PM Reply With Quote
i know big wasa has far more technical knowledge than me maybe i got a duff st170 block that hadnt had all the bolt holes tapped out
big_wasa
posted on 8/8/17 at 09:23 PM Reply With Quote
Just been out and double checked, I have a 2004 focus black top and a 2003 st170. And a pair of plastic plates for patterns.
They fit both just fine. I will say the st170 Os lower holes are blank for the first 10mm as it looks like they are drilled for locating dowls but they are still tapped m10 after this and there is plenty of meat to use it as an engine mount.
I have heard of some lugs being un drilled and un tapped but min are.
The near side must be the same as these are the lugs used for the ac compressor bracket.
[Edited on 8/8/17 by big_wasa]
rayward
posted on 8/8/17 at 09:30 PM Reply With Quote
thanks for taking the time to check ,much appreciated
Ray
