Author: Subject: Can someone fabricate me two of these?
PSpirine
posted on 12/8/17 at 09:23 AM Reply With Quote
Fellow locosters, I need your help!
I'm in the process of doing up a house (hence why car projects are on the back burner).
I've done the manly thing and instead of hiring stuff, went out and bought lots of excessive equipment, one of which is a mobile scaffold tower.
Unfortunately, I only realised too late that it is missing two guard rails, which basically makes it unusable as a couple of things latch to those guard rails.
Given I haven't got a garage to get my welder in at the moment, I was wondering if anybody (ideally not too far) could knock me up two of the following:
It needs to be out of ~38mm section, although I reckon 40mm would just about squeeze into the brackets. The only really critical dimension is the 1425 between centres. The top corners can either be bent, or can be right angles if easier.
Would obviously be more than happy to pay!
[Edited on 12/8/17 by PSpirine]
mcerd1
posted on 13/8/17 at 07:45 AM Reply With Quote
What about key clamps ?
No welding required
Typically comes in 42mm tube sizes, but smaller ones are available
You can get it from loads of builders merchants and some specialist places (just google tube clamp or key clamp)
Some of the specialists will also make welded ones to your spec.
[Edited on 13/8/2017 by mcerd1]
PSpirine
posted on 14/8/17 at 02:30 PM Reply With Quote
D'oh, great idea thanks.
Found them in 34mm spec, which will be absolutely fine!
<100 for everything including cut tubes, excellent.
Thanks!!
