New Topic New Reply
Author: Subject: Roll cage supports brackets
craigdiver
posted on 22/8/17 at 07:27 PM Reply With Quote
Welded in brackets to accept the gudgeon pins on the roll cage support bars. Looking at the book it is not showing any bracing between rear rail and diff cage / suspension mount steelwork, is this bracing needed or does this look ok?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
Nickp
posted on 23/8/17 at 06:20 AM Reply With Quote
Similar to mine, not saying it's right, but it's similar to mine
Nickp
posted on 23/8/17 at 06:22 AM Reply With Quote
Got me thinking now.....what about removable braces back to the diff cage so you can still fit/remove the tank?
craigdiver
posted on 23/8/17 at 06:45 AM Reply With Quote
I agree Nick, for all the structural bracing throughout the chassis, this seems lacking. I'm sure this would give if I ended upside down with large forces on the roll bar.
Interesting that it was ok for IVA, I suppose if it was scrutineered by race marshals as a life saving roll cage, it would fail.
Nickp
posted on 23/8/17 at 06:50 AM Reply With Quote
It isn't even needed for the IVA and hopefully won't be needed for life saving duties either!!
I am considering side / door bars that run from the upper loop forwards to the chassis so it's braced forwards as well as rearwards. Or a full cage, not decided yet.
craigdiver
posted on 23/8/17 at 06:54 AM Reply With Quote
If it wasn't for the seatbelt upper mounts I might have left it off entirely.
Andybarbet
posted on 23/8/17 at 08:45 AM Reply With Quote
Mine go all the way down to the bottom corners, I've seen plenty done similar to yours though.
spare wheel box section
If you look at the Westfields they didn't used to have any bracing, just the bolt on rollbar so I think you will be fine like that.
CosKev3
posted on 23/8/17 at 04:00 PM Reply With Quote
Yeah but you need to remember that the roll bar itself is the main strong point if you were upside down,the rear stays just help to hold the main roll bar upright incase you have any forces trying to push the rollbar forwards/backwards
New Topic New Reply
