Author: Subject: Fuel pump location
Eviljohn
posted on 23/8/17 at 02:22 PM Reply With Quote
Fuel pump location
Hi all. Following advice on my bike carb conversion, mounting the bike pump i got towards the back of the car. Would i have an issue if i mounted it to the fuel tank strap or fixing it to the rear axle? '83 mk2 polo.
CosKev3
posted on 23/8/17 at 02:55 PM Reply With Quote
As long as it's gravity fed you will be OK.
But it's not a good idea to mount to any moving part of the suspension (beam/axle)
Eviljohn
posted on 23/8/17 at 03:12 PM Reply With Quote
Cool. Will bear that in mind. Thank you very much.
jossey
posted on 24/8/17 at 06:52 PM Reply With Quote
The vibration will kill the pump I hung mine on a bracket under the tank just a touch lower than the chassis using a plate and a pole bracket
But wrapped in rad hose to stop it getting damaged
SATELLITE DISH CLAMP BRACKET AERIAL V BOLT POLE BALCONY SKY POLSAT NC+ 17CM
David Johnson
