Author: Subject: Fury Ball Joints
AndyG
posted on 24/8/17 at 10:08 AM Reply With Quote
Fury Ball Joints
I have a fury which needs the front lower ball joint replacing I have spoken to Fury who are struggling to get hold of these does anyone know where I can track some down at short notice as I have a road trip to Prague in a couple of weeks therefore I need to get the parts asap. Any help would be much appreciated.
adithorp
posted on 24/8/17 at 12:41 PM Reply With Quote
They're Sherpa/Transit drag link ends (r/hand thread, off-side). Should be available from a good motor factor.
http://jpsc.org.uk/forum/
AndyG
posted on 24/8/17 at 07:47 PM Reply With Quote
Thanks for the reply do you know what year transit they are from as there seemed to be quite a bit of difference from different years. Thanks
adithorp
posted on 24/8/17 at 08:18 PM Reply With Quote
Think it's this one... https://car-part-info.com/quinton-hazell-qd1117rht/
AndyG
posted on 24/8/17 at 08:32 PM Reply With Quote
Thanks much appreciated.
obfripper
posted on 24/8/17 at 09:03 PM Reply With Quote
Quinton hazel QR1774RHT is the one to replace striker/phoenix/fury/stylus lower arm balljoints where an escort or capri upright is used.
Depending on the design of the replacement, some modification of the taper shank may be needed to allow the taper to fully seat.
Dave
[Edited on 24/8/17 by obfripper]
adithorp
posted on 25/8/17 at 09:18 AM Reply With Quote
Dave
Think that could well be the one. The one I linked to is M20x1.5 and the above is UNF which I seem to remember is whats on.
AndyG
posted on 27/8/17 at 10:28 AM Reply With Quote
I purchased one of these but as you say it needs a but if work to get it to fit. Is this just a case of re-threading it with a unf.
Also I need to purchase some bushes but Fury are struggling to get these do you know of anywhere you can the bushes I need the 4 by the diff replacing but ultimately I would want to replace all of them.
