Author: Subject: How do you store all of your boxed tools
bi22le
posted on 30/8/17 at 08:50 PM Reply With Quote
I'm rearranging my tiny garage and need inspiration.
How do you store all of your pre boxed tools. Things like:
Circular saw
SDS power drill
Dremel
Bits for Dremel
Battery drill
Router
I want them in their boxes as they have stuff with them but they are just stacked up under my bench. They are all different sizes so never stack right.
Thoughts?
Please read my ring story:
ianhurley20
posted on 30/8/17 at 09:31 PM Reply With Quote
Ha ha - exactly my problem. Loads of boxes taking loads of room. I eventually chose one big empty box and put all the extra bits from all the tools into that one box. All the power tools then went on the shelf and all the excess boxes went to the recycling yard. Brilliant. It's been about 4 years since I did it and its been a good solution for me. And - I can get more tools on the shelves!
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
bi22le
posted on 30/8/17 at 10:20 PM Reply With Quote
I considered this. Especially as I have just cleared out an old tool box that I could rip out the old shelves making one large compartment for all the odds and ends.
What do you do about all of the cables, won't them around each tool?
ianhurley20
posted on 31/8/17 at 07:21 AM Reply With Quote
yes - the cables get wrapped around each tool. I have a shelf or two where each tool is placed so I can get at each without moving another (I don't do 3 deep) It still takes up room but an awful lot less than before and I don't have to lift out and open several boxes before finding the right tool. It surprises me how infrequently the box with ALL the bits in gets opened.
Works for me
written off 23/9/18
Smoking Frog
posted on 31/8/17 at 07:42 AM Reply With Quote
Filling cabinet works well if you have the room.
posted on 31/8/17 at 11:38 AM Reply With Quote
Ditto!
I have a metal filing cabinet from work. Boxed tools are stored in a couple of drawers. Works well for me.
Larger tools (circular saw etc) have various locations in my shed. Usually depending on how much effort (or time) I make when putting them away.
Ad to that, some high up shelves is another option. Keeps the floor/workspace tidier and keeps said tools in their boxes as well.
[Edited on 31/8/17 by nick205]
Bluemoon
posted on 31/8/17 at 11:57 AM Reply With Quote
Not sure what is wrong with a shelf?
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
jps
posted on 31/8/17 at 12:41 PM Reply With Quote
I wanted to sort stuff out so it was easy to keep the place tidy- I made some shelves to fit Curver plastic crates (like Eurocrates) - then tried to group stuff together sensibly. So I have:
1 box for all the car parts which are reconditioned / ready to fit
1 for paint aerosols/tins/etc and paint prep items (scotchbrite / wet n dry sheets etc)
1 box with my drill (in its original case) and the different drill bit cases / etc
1 box with any 'fine work' stuff in - so measuring calipers/steel rule/scriber/etc - and my 'dremel' (in it's own box)
Then some shelves which would take a crate - but where I have an actual toolbox - which have the following in:
1 for all electrical work stuff (not well stocked yet - but reels of wires/wire stripper/electricians pliers /etc
1 with the angle grinder and all discs / flap wheel / etc
1 for 'hand tools'.
I also put a wooden back panel up behind my workbench and have some magnetic strips to take spanners / screws & nails to take hammers/adjustable spanners / etc
It's not ideal - but it helps that I don't have space to leave things lying about - so once they come out for a job they have to be chucked back into the appropriate box so I am not tripping over them.
Andybarbet
posted on 31/8/17 at 01:06 PM Reply With Quote
I picked up two of these metal office half height cabinets for free, perfect size for putting blow moulded drill, jigsaw cases etc in
All neat & packed away but convenient height too so I screwed old kitchen worktop on them as my work bench, it works a treat.
https://www.ezrshelving.com/low-office-cabinet.html
Rod Ends
posted on 31/8/17 at 07:23 PM Reply With Quote
Maybe slightly OT, but Halfords are selling socket set cases and trays (NO sockets - just cases)
Seem to recall someone looking for one of these a while ago.
http://www.halfords.com/workshop-tools/storage/tool-boxes/halfords-advanced--120pc-blow-mould-case
Partofthechaos
posted on 1/9/17 at 09:20 AM Reply With Quote
Originally posted by bi22le
What do you do about all of the cables, wind them around each tool?
Reusable cable ties are good for this. No distorted cables and they don't try to escape whenever you move the tool.
