Author: Subject: Aluminium Mesh for Bonnet Vents
L1berator
posted on 31/8/17 at 08:29 AM Reply With Quote
Hello there,
I would like to fit some aluminium mesh vents in the body of my car, but would like to have the mesh bonded from the inside and stretched to sit flush with the outer surface of the fibreglass. Would the best way to do this be to cut a template to the shape of the vent from MDF and then press (or hammer) a smaller blank into the shape? Is it necessary to anneal the aluminium first?
Any advice would be greatly appreciated. Also, has anybody got any photos of this being done - or of the finished product?
Thanks,
Peter
welderman
posted on 31/8/17 at 09:31 AM Reply With Quote
If this works ill be amazed, its been ages since ive done owt like this.
http://locostbuilders.co.uk/forum/4/viewthread.php?tid=115155
Thank's, Joe
I don't stalk people
L1berator
posted on 31/8/17 at 09:51 AM Reply With Quote
Thanks very much!
shindha
posted on 31/8/17 at 11:06 AM Reply With Quote
Hi I have a full set (4) of the Westfield FW body work pre formed mesh vents - possibly not aluminium though let me know if your interested can send some pics.
tims31
posted on 31/8/17 at 11:20 AM Reply With Quote
Originally posted by L1berator
Hello there,
Thanks,
Peter
That how I did mine, MDF cut out of the vent shape and a blank slightly smaller hammered into the mesh and then the sheet bonded into place. The only thing is to do one raised section at a time and then move onto the next to get the positioning correct.
It doesn't come out fully to the depth of the bodywork to make it flush but it does make it look neater than flush with the underside I think.
More pictures here
http://www.martinsfurybuild.co.uk/2016.html#oct_2016
I'm just round the corner from you if you want to take a look
[Edited on 31/8/17 by tims31]
Build: http://www.martinsfurybuild.co.uk/
L1berator
posted on 31/8/17 at 12:03 PM Reply With Quote
Hi Martin - that looks ace - where did you source the mesh from?
Thanks,
Peter
Charlie_Zetec
posted on 31/8/17 at 02:26 PM Reply With Quote
I used stainless mesh from Ford (as used on the < 2001 Mondeo front end) when I did my nosecone, and will probably use the same if/when I do any vents in the bonnet. It's a woven look, so not sure how well it'd take to being hammered/formed around a mould of any description??
tims31
posted on 31/8/17 at 04:12 PM Reply With Quote
Thanks,
Peter
I bought it from Ebay but it came from Poland, cheapest place I found even with postage
http://stores.e bay.co.uk/carbodydesign-eu/ALUMINIUM-MESH-/_i.html?_fsub=1671444010&_sid=1009037200&_trksid=p4634.c0.m322
I still have some left, how much you need?
gremlin1234
posted on 31/8/17 at 05:21 PM Reply With Quote
as I suggested in this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=198102
have a look in a local junk shop / antiques emporium or possibly charity shop, and see if they have any fireguards. and cut the mesh from that
Boothy
posted on 28/10/17 at 05:58 PM Reply With Quote
great idea
