Author: Subject: Fury Scuttle Panel measurement
Markymark
posted on 3/9/17 at 01:21 PM Reply With Quote
Hi All
Is there a kind Fury owner who could measure their front scuttle panel for me please?
I'm looking for the distance from where it attaches to the chassis at the front to where it goes vertical at the back. In line with the steering column if that makes any difference.
Fury Scuttle Panel
Fury Scuttle Panel
This section on the above (thanks Rob, nicked from the internet)
Many thanks in advance
Mark
scudderfish
posted on 3/9/17 at 04:27 PM Reply With Quote
Approx 17cm
https://goo.gl/photos/da3SRTDpfVVVJMpG7
adithorp
posted on 4/9/17 at 10:59 AM Reply With Quote
175mm on mine.
Mine has the chassis with spurious extra 1" length making getting the bodywork to fit difficult. Newer chassis from BAGH/Steve don't have that. Even so, I think it'll need a lot of trial fitting before you trim.
http://jpsc.org.uk/forum/
Markymark
posted on 4/9/17 at 12:53 PM Reply With Quote
Cheers guys
Thanks for that, it's not for trimming as I don't have the body yet!! I just needed an idea of the distance, so where my Alfa 164 steering column comes through, whether the UJ is on the inside or outside the bulkhead (fully sliding as original is adjustable) so I can make up and fit a bracket for the lower column support bearing.
Alfa steering column
I appreciate your help
Mark
