<<  1    2  >>
Author: Subject: Looking to upgrade sierra master cylinder
jps
posted on 9/10/17 at 11:23 AM Reply With Quote
Sierra res can be reused, Voucht on the Haynes forum (am here?) did a template for an alu mount to hold it in the right orientation for a 7 installation (in the Sierra the m/c fits the bulkhead in such a way as it was angled upwards - so the mount compensatates for this.
I got a Mk1 cylinder as NOS from eBay a few years ago - good to see part numbers to show they are available as NNS though!
[Edited on 9/10/17 by jps]
martinnitram
posted on 9/10/17 at 10:07 PM Reply With Quote
Nice work, as you know I'm doing the same job, sierra to Fiat master cylinder, not had mine out on the road yet as have a few other jobs on going.
I ended up with a reservoir from kitspares who are not far from me, came with a nice alloy bracket which saved time with mounting.
Don't know about you but the bottom of the ports is a bit rough and took a real good tighten to get the pipe unions to seat in without leaking, worse one is the 2nd front brake port which I screwed a bleed nipple in to blank it off, ( you ran 2 separate lines ) its a stainless nipple so quite hard against the rough inside of the port and didn't want to seal at first.
Pedal feels better though.
CosKev3
posted on 10/10/17 at 06:51 AM Reply With Quote
I wouldn't mind betting the bleed nipple has the wrong shaped seat to fit correctly?
If you look at a brake pipe fitting flared end it is nowhere near the same shape as a bleed nipple!
flanders
posted on 10/10/17 at 08:18 AM Reply With Quote
yeah i didn't have any issues with leaks bud. I pressure tested the system for 3 hours before filling with fluid.
Im going to re-bleed the system tonight, I think I may still have air trapped somewhere (probably rear calipers or in the cylinder) and im going to adjust the pedal so that there is a tiny bit of play between the push rod and the cylinder
martinnitram
posted on 14/10/17 at 08:59 PM Reply With Quote
Ive now swapped the bleed nipple for a brass bung, and yes there is a noticeable difference in the shape.
<<  1    2  >>
