Lander
posted on 11/9/17 at 06:27 PM |
Pinto coolant pipes
Having recently acquired a new car running a Pinto one of the first things I need to do is to replace all of the coolant pipes. Does anyone have a
diagram showing pipe ID's so I can order new shiny bits without having to dismantle what's there first ?
Thanks,
Ian
snapper
posted on 11/9/17 at 06:30 PM |
Need to check but top of head
Thermostat to radiator top hose is 32mm to 32mm
Bottom hose is 38mm out of pump and 32mm at the radiator
I eat to survive
I drink to forget
Lander
posted on 12/9/17 at 08:28 AM |
Thanks for that as a starter, has anyone got a definitive list ?
Thanks again,
Ian
posted on 12/9/17 at 03:52 PM |
That's as I recall it from my Pinto MK Indy build using a VW Polo radiator.
IIRC the part I struggled with was a fairly tight bend on the lower radiator pipe. A local motor factor let me rummage through their stock to find
what I was after in the end.
