Author: Subject: One-off Parts (CNC etc)
daveb666
posted on 11/9/17 at 06:59 PM Reply With Quote
I'm soon going to need some brackets made similar to the below.
Measurements tbh but roughly 50cm x 25-30cm from 8mm ally plate.
What should I expect to pay for these making - should I go to a local place or send my design off to one of the 'one-off' Internet places?
Thanks in advance.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   daveb666 's Aim
Matt21
posted on 11/9/17 at 07:38 PM Reply With Quote
If these are for mounting some wings... I'd think 8mm is a bit overkill! you'd probably be fine with 4-5mm! weight saving man!
My choice would be a grinder, dremmel, file and a powercoater friend.
I know, I'm no help at all
Instagram: @matt211988
Photobucket
My YouTube
907
posted on 12/9/17 at 06:27 AM Reply With Quote
50 off and I'd be sending drawings off for water jet/laser quotation,
but for 1 off it would be drill holes in the corners to match the radius and a 125mm slitting disc for the straights, sheet from eBay.
( I'm a little confused as the title says "1 off" and your text says "some brackets". )
Whatever cutting method is used to cut it/them there's going to be a lot of filing and rubbing down.
Your excellent drawing has a nice radius on all the cut edges.
As for cost it's whatever the cheapest quote comes back, or nothing if you do it yourself.
Paul G
[Edited on 12/9/17 by 907]
Member of the Suttol Owners Club, the MX5 Owners Club and the BMMC
WallerZero
posted on 12/9/17 at 07:18 AM Reply With Quote
Find a local water cutters. Cheapest is you supply the material and CAD file, cash in hand. I had 2 wing mounts cut for 10 for the pair which were slightly bigger. It was the 8mm Ali that cost 30! I've used my local place a lot on my rebuild and they're much much cheaper than anything else - even laser!
http://zachsgbszero.blogspot.co.uk/
posted on 12/9/17 at 03:23 PM Reply With Quote
Sounds the way to go to me.
8mm thick seems a lot though - could you not use a thinner material?
