Author: Subject: Handbrake options
goaty
posted on 19/9/17 at 05:04 PM Reply With Quote
Handbrake options
Hi
What are the options for handbrakes.
Currently on sierra rear discs but about to change to wilwood power lite rear brake kit.
Currently the car has the handbrake handle of what looks like sierra item mounted on top of the tunnel but right where I want my arm.
What options are there to move it, baring in mind the new brake kit?
ian locostzx9rc2
posted on 19/9/17 at 07:09 PM Reply With Quote
Strikers have the handbrake on the side of the tunnel passenger side works well
mackei23b
posted on 19/9/17 at 08:13 PM Reply With Quote
The older Caterhams have the handbrake under the dashboard on the passenger side.
goaty
posted on 19/9/17 at 08:14 PM Reply With Quote
Will try and search about.
My last kit had it under dash and pulled it towards yourself to put it on. Twist to release
blue2cv
posted on 20/9/17 at 07:05 AM Reply With Quote
If you want to go pull out handbrake, 2cvs use them, i have a few on shelf
goaty
posted on 20/9/17 at 08:59 AM Reply With Quote
Do you have any pictures?
Ugg10
posted on 20/9/17 at 09:09 AM Reply With Quote
On my old fury I had a sierra handbrake mounted inside the tunnel, bit of a squeeze but easy fit if you bend one of the brackets. This was an option rather than putting it on the outside. When release it was fine with the gearstick although it looks tight in the pictures.
Finished it off with a bit of faux carbon escutcheon and a brush type letter box draft excluder.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
40inches
posted on 20/9/17 at 10:01 AM Reply With Quote
I covered mine to form an arm rest.
tunnel
tunnel
jossey
posted on 20/9/17 at 06:38 PM Reply With Quote
I use one from a ford ka
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
goaty
posted on 20/9/17 at 07:58 PM Reply With Quote
Not sure about putting it in the tunnel. I should have room as there no gbox in there.
Don't fancy it on the side though.
How have you mounted your ka one? Any pics?
Thanks for the input all
paulc
posted on 20/9/17 at 08:22 PM Reply With Quote
I've inset mine into the tunnel so its flush when its off.
Handbrake sunk into tunnel
It seemed like a good idea at the time, but was quite a big job in the end.
Paul
mackei23b
posted on 21/9/17 at 04:36 PM Reply With Quote
I have to say that looks great, well done!
Paul
goaty
posted on 21/9/17 at 08:18 PM Reply With Quote
That does look good.
Not sure my skills would give a good clean finish.
Will have a look over weekend.
About to order some rear wilwoods so can do all the work In one hit too
posted on 21/9/17 at 08:30 PM Reply With Quote
That looks sweet. I put the handbrake in the passenger footwell and no complaints (or handbrake turns) so far!!!!!
But that looks great.
Ron86
posted on 22/9/17 at 08:27 AM Reply With Quote
That is an awesome solution. Must have been a f*#%! to do though!
paulc
posted on 22/9/17 at 05:47 PM Reply With Quote
Glad everyone likes it.
I'm fortunate in that I have access to some very useful stuff at work.
The ally trim was cut out on a CNC mill (it'd look rather different if i'd done it by hand)
The Tub/Bowl underneath was 3D printed by a mate who has a 3D printer.
After Id done it I realised I'd made routing the rear brake pipe, loom, fuel lines etc much more "interesting".
Paul
jrod
posted on 25/9/17 at 08:11 AM Reply With Quote
Trigger handbrake bolted to side passenger side of tunnel.
