Author: Subject: Whats this bolt called....
prawnabie
posted on 26/9/17 at 09:40 PM Reply With Quote
Hi all,
I have a sheet metal folder and the folding bar is secured by 6 M10 bolts. Now this is a PITA when folding large sheets as they all need to be nipped and then undone for every fold. I am after a bolt with a kind of vice handle "Tommy bar" on the end so I can nip them by hand for thinner sheets - has anybody seen such a thing?
Thanks,
Shaun
wood85
posted on 26/9/17 at 10:23 PM Reply With Quote
Many different types of handles on bolts - is this what you are looking for:
Ganter Gn6336.4-St-32-M6-20 Star Knob; Polyamid; Bolt
Or try "T Strap Bolts".
cliftyhanger
posted on 26/9/17 at 10:26 PM Reply With Quote
https://www.ebay.co.uk/p/2-X-M6-X-35mm-German-Made-Din316-Wing-Bolt-WINGBOLT-Nut-Butterfly-Screw/1156232449?iid=122675022281
5 x M6 X 20mm 6x20 GERMAN MADE DIN316 WING BOLT WINGBOLT BUTTERFLY THUMB SCREW
Any good?
Madinventions
posted on 27/9/17 at 12:51 AM Reply With Quote
Something like this?
https://www.goodhanduk.co.uk/Catalogue/Standard-Parts/Machine-Jig-Devices/K0756-Thrust-Screws-With-Fixed-Slidi ng-Handles-Size-M6-M20/PAD-SCREW-WITH-MOVABLE-SPINDLE-M10-L150-K0756210X50
Ed
[Edited on 27/9/17 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Madinventions 's Aim
posted on 27/9/17 at 07:50 AM Reply With Quote
Is the metal into which the bolts go thick enough for countersink heads?
Allen drive (recessed) head countersink bolts are pretty readily available.
That way you could leave the bolts done up.
prawnabie
posted on 27/9/17 at 07:33 PM Reply With Quote
Hi all,
Thanks for the replies, the bolts need to be done up to secure the sheet to be folded, then undone to release it.
It would either need to be an M10 bolt with a fixed or sliding "Tee" on it not a hex head.
Thanks,
Shaun
mcerd1
posted on 28/9/17 at 01:06 PM Reply With Quote
hows about welding a cheap socket (ebay etc) with a T bar onto each one (maybe with a short extension)
Angel Acevedo
posted on 28/9/17 at 03:53 PM Reply With Quote
How about making some with Eyebolts and regular bolts fitted through the eyes?
