Author: Subject: Zetec inlet insulation plate
ttalps2000
posted on 2/10/17 at 01:52 PM Reply With Quote
Do I need to use the plastic insulation plate on the inlet manifold on the Zetec? I have one, but need new gaskets, which appear to be a fortune unless I buy a complete top-end gasket set!
I have used the DanST Engineering gaskets in the past and he does a thick version of the inlet gasket which states that I shouldn't need to use the plastic spacer?!
furryeggs
posted on 2/10/17 at 02:38 PM Reply With Quote
You shouldn't need it unless theres any air/vacuum chanels behind it. You will have to get shorter bolts though or shorten them.
I assume your using the standard plastic inlet.
ttalps2000
posted on 2/10/17 at 02:42 PM Reply With Quote
ok. I'm using a DCOE manifold
chris
posted on 2/10/17 at 02:51 PM Reply With Quote
I thought you only used the zetec inlet plate if you are going injection a webber manifold would bolt straight to head you could use one of Danst gaskets
furryeggs
posted on 2/10/17 at 03:15 PM Reply With Quote
I have a danst manifold and thicker gasket bolted straight to the head.
ttalps2000
posted on 2/10/17 at 03:17 PM Reply With Quote
ok, sounds the way to go!
Thanks for the help!
