Author: Subject: Brake reservoir and warning lamp
the_big_1
posted on 9/10/17 at 06:01 PM Reply With Quote
Hi guys,
For IVA, is there a problem using one reservoir to feed both front and rear brake master cylinders?
Also, in the manual the lamp has to be checked etc. Would it be ok that the lamp comes on with the ignition and goes out once the engine is running? Would still come on if the fluid gets low etc.
Cheers!!
gremlin1234
posted on 9/10/17 at 06:43 PM Reply With Quote
should be fine, but note; often the testing of the light is done by having it as a handbrake warning light, which may be easier
the_big_1
posted on 9/10/17 at 06:46 PM Reply With Quote
Guess I could do it both ways as it will be an ecu that’s monitoring it.
adithorp
posted on 9/10/17 at 08:12 PM Reply With Quote
You can use a single res' but it has to have an internal division with one outlet from each side. That way should one brake circuit leak, the other retains it's fluid.
http://jpsc.org.uk/forum/
the_big_1
posted on 9/10/17 at 08:15 PM Reply With Quote
Cheers makes sense. Will have to use the two single reservoirs and two level sensors.
Cheers all!
