Author: Subject: Dedion axle
goaty
posted on 15/10/17 at 05:10 PM Reply With Quote
Dedion axle
Anyone got one gts or similar knocking about?
posted on 16/10/17 at 09:28 AM Reply With Quote
I don't have one.
Are you wanting one to fit an existing chassis?
goaty
posted on 16/10/17 at 11:54 AM Reply With Quote
Hi
That's my plan.
Little project for winter
Charlie_Zetec
posted on 16/10/17 at 01:02 PM Reply With Quote
Not sure if there's anyone that stocks them "on the shelf", but still commonly used in some racing cars/series.
I'd suspect getting hold of a pre-made one will require a real stroke of luck now that GTS Tuning is no more, and DTR Cars (who took it over) have done the same.
I'd look up the McSorely build plans (GTS W7DE uses the +442 version), as I think they had the details on them for the manufacture of the DeDion setup - and have a chat with your local friendly fabricator!
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
goaty
posted on 16/10/17 at 01:14 PM Reply With Quote
Cheers for the info.
Not a easy as I hoped it would be
selrahc360
posted on 17/10/17 at 05:35 AM Reply With Quote
Dion rear axle source
Alfa romeos had them in the gtv6 and alfetta.
Hope that helps.
View User's Profile View All Posts By User U2U Member   selrahc360 's Yahoo
goaty
posted on 17/10/17 at 05:49 AM Reply With Quote
Will have a nose.
Andy D
posted on 17/10/17 at 07:07 AM Reply With Quote
Caterham?
https://caterhamparts.co.uk/de-dion-tube/2588-de-dion-tube-narrow-buttress-s3.html
posted on 17/10/17 at 08:23 AM Reply With Quote
Originally posted by goaty
Hi
That's my plan.
If that's the case will you not need it to have specific dimensions for track, mounting points etc?
goaty
posted on 17/10/17 at 12:10 PM Reply With Quote
I plan to fabricate all the mounts etc myself so anything the correct width should be possible.
I have been looking at the option of caterham parts too
TimC
posted on 17/10/17 at 06:51 PM Reply With Quote
I wonder if Retro Power would make you one?
super-ron
posted on 18/10/17 at 03:48 AM Reply With Quote
I have one I won't be using now, made to accept sierra rear hubs, will come with the 4 trailing arms with bushes and panhard rod too (I will be keeping the sierra bits)
lots more pics here:
http://www.locostbuilders.co.uk/viewthread.php?tid=208037
goaty
posted on 18/10/17 at 05:08 AM Reply With Quote
U2u sent
