Author: Subject: Lap top with serial port
Shooter63
posted on 17/10/17 at 05:46 AM Reply With Quote
As the heading I'm looking for the above for the obvious reasons, I would prefer running Windows 7 , as it's going down the workshop external condition not important.
Shooter
ElmrPhD
posted on 17/10/17 at 07:05 AM Reply With Quote
Not sure if it would suit your needs, but you are aware that you can get a USB-to-serial-port adapter(cable), right? That's what I had to do in order for my laptop to com' with both my Race-Technology Dash2 and my Omex 710. Just an option to consider.
Good luck.
Steve, in the NLs (who will be taking the MNR to the tuner later today - woohoo!)
posted on 17/10/17 at 07:47 AM Reply With Quote
Good luck.
One of our engineers at work uses the same to connect an older RS232 device to his up-to-date laptops USB port. Works fine for him and saved him a lot of grief trying to find a laptop with a serial port.
On the subject of buying laptops I've used Laptops Direct for both work and home. No connection to me, but good service, products and prices...
https://www.laptopsdirect.co.uk/
stevebubs
posted on 17/10/17 at 09:44 AM Reply With Quote
You can also get Bluetooth serial adapters.... avoids having to run wires and balance laptop in difficult places...
Ugg10
posted on 17/10/17 at 10:42 AM Reply With Quote
USB>Serial adaptors work well but there are two (at least) different chip sets. IIRC the Emerald K3 ecu was only compatible with one of them so may be worth checking to see if the kit you are connecting to has a preference.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
rodgling
posted on 17/10/17 at 02:02 PM Reply With Quote
The USB-serial adapters with FTDI chips usually work well for connecting to ECUs etc.
jossey
posted on 17/10/17 at 04:44 PM Reply With Quote
I have a few USB to serial cables all work fine all cost a few quid off eBay
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
Shooter63
posted on 17/10/17 at 05:52 PM Reply With Quote
Yup got a connector but I need a laptop down the workshop so I might as well get one with a serial port.
Shooter
flak monkey
posted on 19/10/17 at 06:59 PM Reply With Quote
I have a Dell one here with a new battery in it, decent spec...
Sera
https://www.facebook.com/sera.jay666
Shooter63
posted on 19/10/17 at 10:13 PM Reply With Quote
What sort of money are you looking For?
Shooter
flak monkey
posted on 20/10/17 at 11:22 AM Reply With Quote
Shooter
75 posted
It's a half decent spec, clean windows 7 on it.
Sera
