Author: Subject: Where in the UK can I get these?
JC
posted on 18/10/17 at 08:59 AM Reply With Quote
Hi, I have a gel battery with spade terminals. Does anyone know if you can get these in the UK? Found loads in the US....
Battery
Battery
40inches
posted on 18/10/17 at 09:55 AM Reply With Quote
Battery
Battery
Would this do the same job? http://www.vehicle-wiring-products.eu/product.php/556/copper-tube-terminals
JC
posted on 18/10/17 at 10:40 AM Reply With Quote
Well, yes kind of - except that I have a perfectly good set of battery leads from the donor car, and the geometry of post fittings works better.
I plan to use those as a fall back!
r1_pete
posted on 18/10/17 at 12:01 PM Reply With Quote
These are similar
https://www.ebay.co.uk/i/401180788485
JC
posted on 18/10/17 at 01:03 PM Reply With Quote
Yes - seen a fair few of those. I guess some delicate attention with a file, drill and tap would sort them.
r1_pete
posted on 18/10/17 at 01:27 PM Reply With Quote
Or you could make them vertical with a couple of brass angle brackets...
Mike Wood
posted on 21/10/17 at 05:21 PM Reply With Quote
Hi
Make up some battery leads with the correct sized terminals crimped on to them, or buy pre made leads:
https://www.merlinmotorsport.co.uk/s/electrical/cable-eyelets-terminals
https://www.lasaero.com/products/article/C046EBXXP
http://www.vehicle-wiring-products.eu/section.php/93/1/pre-made-battery-leads
http://www.vehicle-wiring-products.eu/section.php/97/1/terminals-connectors
http://www.vehicle-wiring-products.eu/section.php/95/1/crimp-tools
https://www.electricalcarservices.com/battery-leads-made-to-order/c-p-0-0-535
NB Merlin Motorsport will also make up leads.
Mike
[Edited on 21/10/17 by Mike Wood]
