Author: Subject: Turning an engine over by hand - how freely should it turn?
james h
posted on 20/10/17 at 06:10 PM Reply With Quote
As above!
I've taken the heads off the V8 in my '98 LS400, to diagnose a knocking/tapping sound (suspected bent valve due to hydrolocking from a heavily leaking injector).
Both heads are off - I'd have thought the crank would turn consistently and freely - but no!
As cylinders 1 & 6 reach TDC (at the same time), it becomes very stiff to turn over. Is this normal for a V8?
Cheers!
James
gary gsx
posted on 20/10/17 at 07:24 PM Reply With Quote
Seems weird to bend a valve in that way did it lock solid? May of bent a rod.
Gary
daviep
posted on 20/10/17 at 07:30 PM Reply With Quote
Not familiar with this particular engine, is there a balancer or anything else driven from the crank that might affect rotation?
On a side note never heard of a valve bending due to hydraulicing, far more likely to bend a rod, have you checked that all pistons are coming up to the same height? also look for unusual marks on the bore.
Davie
james h
posted on 20/10/17 at 07:47 PM Reply With Quote
Just the harmonic balancer on the front, the belt is off. It's an auto, something in the transmission maybe?
My first job tomorrow in daylight is to check properly the bores and piston heights - a quick inspection shows it to be ok.
I'm thinking valves because the compression is about half what it should be on the cylinder which had the leaky injector (the compression test wasn't done by me mind). Surely a slightly bent rod wouldn't cause such a massive drop in compression? Though I'm willing to be educated on this topic!
theconrodkid
posted on 20/10/17 at 07:55 PM Reply With Quote
could be a bent rod, see if there is any height difference when pistons are at tdc
who cares who wins
pass the pork pies
froggy
posted on 20/10/17 at 10:35 PM Reply With Quote
Rods bend on these post 94 engines , I’ve done one on my turbo 1uz bending it until the underside of the piston hit the crank web
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
posted on 21/10/17 at 06:51 AM Reply With Quote
If the injector was leaking to the point the cylinder suffered from a hydraulic lock it will more likely to have suffered bore wash than bend a valve. Bore wash will cause wear to Pistons, rings and bore causing lost compression .Quick test for bent valve is to lay the head flat with both suspect valves closed and fill the chamber with liquid( degreaser, petrol etc) then check the ports for signs of leakage.
froggy
posted on 21/10/17 at 07:33 AM Reply With Quote
I bent the rod until the piston hit the crank and it was only a couple of mm down in the bore at tdc
perksy
posted on 21/10/17 at 11:46 AM Reply With Quote
As above, Bent Rod ?
Saw this on a Subaru Imprezza once
Sam_68
posted on 21/10/17 at 11:54 AM Reply With Quote
Originally posted by james h
Both heads are off...
I'm thinking valves ...
I'm confused...
ian locostzx9rc2
posted on 21/10/17 at 12:00 PM Reply With Quote
It still could be something to do with the transmission?
james h
posted on 21/10/17 at 12:52 PM Reply With Quote
I'll give this a go, thanks
james h
posted on 21/10/17 at 12:55 PM Reply With Quote
I'm confused...
I took the heads off to send to a local engine specialist, (not sent just yet) to check over. I am not too confident on being able to spot a slightly unseated valve. Although the technique mentioned before sounds useful.
My thinking being, if it's a damaged valve the heads will have to come off anyway, and if the rod is bent, the engine is buggered anyway.
james h
posted on 21/10/17 at 04:08 PM Reply With Quote
And the winner is.... Froggy!
Cylinder 8, TDC:
Cyl 8 TDC
Cyl 8 TDC
Cylinder 7 (the one with the leaky injector), TDC:
Cyl 7 TDC
Cyl 7 TDC
Time for a nice V8 coffee table.
The resistance turning the engine over was at Bdc for cyl 7. Clearly exactly the same happened to my engine, as it did to Froggy's. Bummer.
[Edited on 21/10/17 by james h]
froggy
posted on 21/10/17 at 05:02 PM Reply With Quote
I’ve got plenty of spare rods if you want one . It won’t have done any damage . I slapped a rod in mine and it’s fine and mines turboed
mackei23b
posted on 21/10/17 at 05:48 PM Reply With Quote
A big end bearing can give the same effect.
To check the big end when you rotate the crank and the piston stops moving for a period (almost like a flat spot) at the top this would indicate a big end. Just to rule that one out....you did mention some knocking....
froggy
posted on 21/10/17 at 05:59 PM Reply With Quote
Knocking will be the underside of the piston scuffing the crank web .
In n/a form it’s pretty tough to damage a 1uz unless it’s got no oil in
mackei23b
posted on 21/10/17 at 06:56 PM Reply With Quote
Thanks, that would certainly explain the tight spot as well....
james h
posted on 22/10/17 at 02:10 PM Reply With Quote
I may very well be sending you a u2u soon! Thanks, that would be brilliant.
I have a limited mount of time I can put in to change the rods myself, but it might not take too long to get the engine out the car as it is now. Whether or not I'm brave enough to attempt the whole job myself, I'll have to see!
James
froggy
posted on 22/10/17 at 02:32 PM Reply With Quote
Pretty straight forward job . Just need to check the old head bolts for any aluminium from the block threads and clean them with a tap and airline before building . Gasket sets and bolts are cheaper to have shipped from America than here as they’re hard to find anything non genuine
coyoteboy
posted on 22/10/17 at 06:54 PM Reply With Quote
Going back to the original question - I can't turn my V8 over by hand, even with the plugs out I need a wrench and a good 20lbft. My 3SGTE turns over a bit easier, but that's not surprising as it has 4 fewer cyls with 1/2 the ring friction.
daviep
posted on 22/10/17 at 07:53 PM Reply With Quote
The cam(s) will make it lumpy even with plugs out, OP has the heads off so no cam effect so should be reasonably smooth.
