Author: Subject: GTS PANTHER - Upright Choice
sammini7
posted on 20/10/17 at 06:56 PM Reply With Quote
Hi guys I have purchased a GTS Panther kit, does any body know what uprights are to be used with the kit Cortina or Sierra?
Many Thanks
big-vee-twin
posted on 20/10/17 at 08:23 PM Reply With Quote
Both, it was a choice you made when buying. You will need to identify what you have, by measuring them up and comparing
Mine are Sierra
http://www.triangleltd.com
Yorkie
posted on 20/10/17 at 10:24 PM Reply With Quote
As big-vee-twin says the kit could be specified with either.
Measure the distance from the bushes to the ball joints and iíll compare with mine.
I have the Sierra uprights.
big_wasa
posted on 21/10/17 at 09:08 AM Reply With Quote
It was just the top wishbones that where differant. Shorter for the Sierra. I did have the drawings once upon a time.
birdii
posted on 21/10/17 at 09:59 AM Reply With Quote
Just looked at the drawing I have and it shows 242mm from bush tube centre to the outer edge of the top link tube - this is for Sierra uprights.
If you need either sierra or Cortina uprights I have a pair of both to sell (with calipers).
Dan
sammini7
posted on 21/10/17 at 11:10 AM Reply With Quote
Thanks for your help.
sammini7
posted on 22/10/17 at 04:23 PM Reply With Quote
Turns out I have the sierra setup...thanks for all the help guys.
I had hoped that I had the cortina setup as I prefer the simpler upright design and reduced weight, but Sierra it is!
