Author: Subject: 4WD Ford Sierra dif. questions
voucht
posted on 21/10/17 at 09:32 PM Reply With Quote
Someone in France, where I live, is selling a complete rear running gear from a 4WD Ford Sierra. (differential, driveshafts, and complete disc brakes)
I might be interested in purchasing it to fit on my Haynes Roadster this winter, but first, I have few questions for the Ford specialists on here please:
1 - On the add, it says that the rear diff is originally an LSD. Is that true? Did the Sierra 4x4 come with an OEM LSD?
2 - Do you guys know the ratio of the differential on a 4WD Sierra?
Thank you!
Sylvain
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
loggyboy
posted on 21/10/17 at 11:13 PM Reply With Quote
Yes lsd was fitted to most 4x4. Likely to be a 3.62 i think. But can vary on model and year.
[Edited on 21-10-17 by loggyboy]
Mistral Motorsport
posted on 22/10/17 at 07:32 AM Reply With Quote
Check the ID tag bolted to the diff , then check against the Sierra diff info sticky on this forum.
posted on 22/10/17 at 10:13 AM Reply With Quote
Dax (a uk kit supplier) used to make a Rush "Quadra" 4wd 7 type kit that used a Sierra 4x4 as the donor car. I don't know if the front and rear differentials were LSD or not though. I do know that the drivetrain added significant weight and complexity though. I'm also not sure that Dax even trade anymore either.
[Edited on 22/10/17 by nick205]
snapper
posted on 22/10/17 at 11:44 AM Reply With Quote
All 4x4 Ford Sierra’s has a Ford viscous LSD
Most were 7” & 3.62 the 2.0L 4x4 DOHC had the 3.9 LSD
The Cosworth Sierra’s had 7 1/2” 3.64
The later Sierra Sapphire had 7” 3.62
I eat to survive
I drink to forget
Ben_Copeland
posted on 22/10/17 at 03:52 PM Reply With Quote
Mine was a xr4x4 2.0L. Came with 3.9 diff (lsd)
[Edited on 22/10/17 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
View User's Profile View All Posts By User U2U Member   Ben_Copeland 's Aim This User Has MSN Messenger
fregis
posted on 22/10/17 at 04:11 PM Reply With Quote
Rear diff LSD 7" diff (dohc)
Front diff open
Center diff viscose 66/34 % F/R
2.9 / 2.8 v6 and cosi used 3.62 ratio, 2.0 dohc used 3.92 ratio.
rear suspension. with abs- disc brake, without abs- drum brake (but drive shafts bolt type)
[Edited on 22/10/17 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
voucht
posted on 22/10/17 at 05:38 PM Reply With Quote
Thank you very much for all the very useful answers! I've got the infos I needed.
It should be great that this dif for sale is a 3.92, as it is what I currently have on my car. But I have only small hopes as it looks to be very rare. I'm going to ask the owner.
Thanks again!
Sylvain
