starterman
posted on 22/10/17 at 02:02 PM |
Temperature sensor
On a zetec blacktop do I need to use the standard temperature sensor in the head or can I use a different one? If so where is the best place to put
it?
Mike
posted on 22/10/17 at 02:09 PM |
Depends what you want it for...
Standard one tells the ecu what the temp is, doesnt work with a gauge..
Early engines had two sensors, in the thermo housing, one for the ecu (on top) and one underneath with an 1/8th NPT thread for the gauge.
Is yours the late one with the sensor in the head under the inlet manifold?
starterman
posted on 22/10/17 at 02:12 PM |
Yes, sensor under inlet manifold. Only need it for the gauge. The gauge came with a sensor so it seems logical to use that one if possible.
