Author: Subject: Zetec turbo oil feed
hazardpro
posted on 30/10/17 at 03:57 PM Reply With Quote
Hi guys.
To all Zetec turbo users.
Im running a Zetec black top with Escort RS (t3) turbo.
Im currently rebuilding the turbo as its knackered and I want to be sure its getting enough oil.
The oil feed union on my setup has a pretty small hole, only 2mm which is think is too small. It can be opened up (up to) 4mm if needed.
Just wondered if anyone new what they were running?
I was told there is a simply test you can do to ensure enough oil it getting to your turbo, and it should be (at least) 300ml running out the turbo oil outlet within a 60 second period....
H
jossey
posted on 30/10/17 at 04:41 PM Reply With Quote
4mm here it's done 30 or so track days and been ok.
David Johnson
hazardpro
posted on 30/10/17 at 04:57 PM Reply With Quote
Thats good to know - as mine is 2mm and probably why the turbo is fried!
Do you have any spec, pics etc of your setup?Always nice to know what and how other people are running zetec turbos
H
jossey
posted on 30/10/17 at 05:04 PM Reply With Quote
Will upload some for you.
David Johnson
theduck
posted on 30/10/17 at 05:05 PM Reply With Quote
I use -4 an line with a 1mm restrictor at the turbo end on my pinto, so far so good.
hazardpro
posted on 30/10/17 at 05:09 PM Reply With Quote
-4?
Do you know the overall dia of the inlet? on the union?
theduck
posted on 30/10/17 at 05:17 PM Reply With Quote
https://en.wikipedia.org/wiki/AN_thread
3/16 inch or 4.5mm
hazardpro
posted on 30/10/17 at 05:32 PM Reply With Quote
Ah ok thanks.
Sounds like me 2mm is way to small!
big_wasa
posted on 30/10/17 at 05:46 PM Reply With Quote
Depends on your restrictor. My Td04 has m10 banjos at the block and turbo.
The Impreza banjo has somthing like a 1.6 hole.
Looks small but I can tell you there is lots of oil coming from the return.
[Edited on 30/10/17 by big_wasa]
