Author: Subject: What's this fitting type called?
Mr Whippy
posted on 3/11/17 at 12:24 PM Reply With Quote
Can someone identify the fitting type here? it seems a very common power steering type and I have one very similar but need a replacement o-ring (lost the original) and need to look up the spec.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
Dingz
posted on 3/11/17 at 02:03 PM Reply With Quote
Used to deal with this sort of thing before I retired, not sure of the name but the O ring material is probably HNBR.
went on and on.
Mr Whippy
posted on 3/11/17 at 02:16 PM Reply With Quote
ok thanks I'll keep that in mind
owelly
posted on 3/11/17 at 03:18 PM Reply With Quote
Try swivel O-ring flare.
http://www.ppcmag.co.uk
motivforz
posted on 3/11/17 at 06:39 PM Reply With Quote
If you measure the diameter of the o-ring, and the diameter it seats on, I can find a catalogue size for you if you like?
posted on 4/11/17 at 08:17 AM Reply With Quote
If it's a power steering fitting then make sure whatever you use is resistant to power steering fluid!
I'm sure you know that anyway, but since I don't know the name of the fitting I thought I'd add it.
snapper
posted on 4/11/17 at 08:56 AM Reply With Quote
More regularly know as Nitrile
I eat to survive
I drink to forget
Mr Whippy
posted on 4/11/17 at 01:21 PM Reply With Quote
Sadly I don't have the original o ring any more i went on the incorrect assumption it would be easy to replace and didn't put it safely aside
Dingz
posted on 5/11/17 at 06:53 PM Reply With Quote
Nitrile is NBR, Nitrile Butadiene Rubber, ok for about 90C
HNBR is Hydrogenated Nitrile Butadiene Rubber, which is good for just shy of 150C, you could see temperatures of around 120 in a power steering system. If desparate you could try Viton which is FKM a Fluoroelastomer which will be fine for the high temperature but could leak at about -10C.
went on and on.
motivforz
posted on 5/11/17 at 08:12 PM Reply With Quote
okay - can you measure the shaft it fits on, and the bore it sits in? I could have a pretty good guess what size it should be from those two numbers.
Viton or nitrile as above would be the likely candidates.
I'm curious about the viton being no good for below -10C, is this a shrinkage issue or brittleness or something else? I've used viton for a variety of ambient applications and not had an issue, although they're replaced regularly. My only concern with Viton is the effect of fire damage - it turns into a pretty corrosive substance.
Dingz
posted on 5/11/17 at 11:24 PM Reply With Quote
The elastomers generally shrink slightly with low temperatures but critically they loose their elasticity, become solid and not exert any sealing force. The material spec will have a figure known as Tr10 which is the temperature below which the compound will not necessarily seal. It is a measure of its residual elasticity. There are specialised low temperature Vitons which would go down to something like -30.
The terrible example of low temperature failure was the Challenger Shuttle launch, those O rings were perfluoroelastomers which have a temp range of roughly +300C but probably a low end of about +5C.
Sorry for the lesson and back to the original question, its a shame you haven't the old part, if it's a Nissan part its probably a Japanese standard size. Is there a similar fitting in the system? if so carefully measure the id of the O ring and even more carefully the cross section to try and find the correct one.
went on and on.
coyoteboy
posted on 6/11/17 at 01:55 AM Reply With Quote
Originally posted by motivforz My only concern with Viton is the effect of fire damage - it turns into a pretty corrosive substance.
http://www.hse.gov.uk/mvr/topics/fluoroelastomers.htm
Report your local potholes, it actually works!
