Author: Subject: hazard fast flash - SOLVED
chris_smith
posted on 8/11/17 at 05:20 PM Reply With Quote
iv used the original mx5 loom, original mx5 hazard switch/relay, RDX led rear indicators, motorbike front indicators, and led side repeaters
when operating indicators to turn left or right everything flashes at correct speed
when operating hazards i get fast flash? but if i disconnect the front indicators it flashes at normal speed?
anyone know whats going on or how to solve?
[Edited on 9/11/17 by chris_smith]
posted on 8/11/17 at 05:23 PM Reply With Quote
On older cars a blown bulb used to make them flash faster - have you checked all the bulbs are working?
chris_smith
posted on 8/11/17 at 05:30 PM Reply With Quote
all indicators work fine when operating for turn signal
posted on 8/11/17 at 06:10 PM Reply With Quote
Try replacing the LEDs with bulbs.
martin500
posted on 8/11/17 at 08:09 PM Reply With Quote
You probably need resistors because the LED lamps have a different resistance to conventional bulbs, google LED flasher resistors
Martin
gremlin1234
posted on 9/11/17 at 10:34 AM Reply With Quote
or a more modern 'electronic' flasher unit
Mr Whippy
posted on 9/11/17 at 12:51 PM Reply With Quote
yeah you can get an LED chip controlled flasher relay from Halfords (just two connections) which solves all these problems
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
chris_smith
posted on 9/11/17 at 05:24 PM Reply With Quote
Problem now solved thanks for everyone’s input
Used resistors
avagolen
posted on 9/11/17 at 05:25 PM Reply With Quote
If your flasher is 3 pin, you can also get fixed rate flashers in that format.
The important term is 'fixed rate' .
The disadvantage is that you do not get any indication of a failed bulb / led
