<<  1    2    3    4  >>
Author: Subject: 2.3L supercharged Locost
J666AYP
posted on 3/4/18 at 11:02 PM Reply With Quote
Ok that image does not seem to work, lets try again....
J666AYP
posted on 3/4/18 at 11:06 PM Reply With Quote
Froggy,
"Throttle pre charger will stop any issues , the little Mini Cooper bypass valves are only £30 and plenty big enough if you run a throttle in front of the charger "
By that do you mean having the throttle body infront of the supercharger instead of on the inlet manifold?
Or by throttle do you mean have the mini one venting into the front of the charger?
Jay
froggy
posted on 4/4/18 at 11:21 AM Reply With Quote
If you set it up as in the pic but with a big dump valve close to the throttle on the inlet manifold you should be ok . The bypass will allow the column of compressed air a way out but a blow off valve right by the throttle should stop most of the pressure spike as you lift . If you ditch the maf and just run it map/Tps it will save a bit of plumbing as well
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
J666AYP
posted on 4/4/18 at 05:38 PM Reply With Quote
Thanks for the input Froggy, better to find these things out now than later.
Jay
J666AYP
posted on 5/4/18 at 05:56 PM Reply With Quote
Had to change things about slightly....
J666AYP
posted on 7/4/18 at 04:45 PM Reply With Quote
Well that was not a fun job!
J666AYP
posted on 10/4/18 at 09:10 PM Reply With Quote
Abit more done... Just waiting on payday so I can get my bypass valve and some other bits.
Ran out of sanding belts so I have not finnished smoothing out the ports yet
J666AYP
posted on 12/4/18 at 07:07 PM Reply With Quote
Bit of a boring afternoon waiting for pay day. Done abit of port/gasket matching to smooth out the airflow (the man at mercedes that designed this engine needs a stern word in his ear).
Just need some sanding/polishing bits for the dremmel now to finish it off.
Angel Acevedo
posted on 13/4/18 at 01:30 PM Reply With Quote
What product are you using to paint your exhaust?
J666AYP
posted on 13/4/18 at 05:58 PM Reply With Quote
Hi Angel,
Its just some old spray paint to make the scratches/defects show up better for ease of sanding. When the parts are to the standard I want they will be ceramic coated to keep the temps down.
Jay
J666AYP
posted on 14/4/18 at 06:28 PM Reply With Quote
Another day of plodding along, on the plus side I have sorted my gearbox mounts. Will be seam welded up when I can turn the chassis over.
J666AYP
posted on 17/4/18 at 11:49 PM Reply With Quote
Ok steel scuttle it is then...
J666AYP
posted on 26/4/18 at 02:29 PM Reply With Quote
Been a busy couple of mornings, the bypass valve is now all sorted. Flange plate for inlet is made and ready for welding.
J666AYP
posted on 27/4/18 at 10:52 PM Reply With Quote
Note to self... next time wear gloves!!!!
J666AYP
posted on 30/4/18 at 06:32 PM Reply With Quote
J666AYP
posted on 1/5/18 at 03:07 PM Reply With Quote
Just knocking up some templates for the carbon pannels. BTW does anyone know how to cut carbon sheets without chipping the resin?
J666AYP
posted on 3/5/18 at 04:29 PM Reply With Quote
Well got my new alternator all mounted. And started a new inlet manifold because of my schoolboy error on the last one.
[Edited on 3/5/18 by J666AYP]
Angel Acevedo
posted on 4/5/18 at 12:07 AM Reply With Quote
By any chance you know which car that alternator comes from?
Thaks in advance.
J666AYP
posted on 4/5/18 at 12:23 AM Reply With Quote
Angel,
The altenator is a denso one, Starterman on
this forum sells them (very well priced too).
I could not say what car it is made for in all honesty.
Jay
J666AYP
posted on 15/5/18 at 01:40 AM Reply With Quote
Abit of slow progress...
Made and welded on the mounts for the side mirrors, finished the altinator mounting, changed the bearings in the supercharger and plated the engine bay.
CosKev3
posted on 15/5/18 at 10:14 AM Reply With Quote
Coming on nicely
Centre console/tunnel looks really good like that in bent tube
You realise the side repeaters in the mirrors won't pass IVA?
Ugg10
posted on 15/5/18 at 11:39 AM Reply With Quote
For cutting fibreglass I used the tungsten carbide (?) jigsaw blades, look like emery paper on a blank jigsaw blade so no teeth to chip the gel coat, worked pretty well.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
J666AYP
posted on 15/5/18 at 03:10 PM Reply With Quote
CosKev3, Why wont they pass? because of the edges not being rounded? (not questioning your knowledge, just want to know what I have missed).
Jay
J666AYP
posted on 15/5/18 at 03:11 PM Reply With Quote
Ugg10, thanks mate I will take a look into those for sure.
Jay
CosKev3
posted on 15/5/18 at 08:07 PM Reply With Quote
Jay
No,because the side repeater can't be viewed from all the angles required for IVA
If you look in the manual side repeaters need to be in view from the rear as well as the front,all the angles and heights are shown in the manual.
[Edited on 15/5/18 by CosKev3]
<<  1    2    3    4  >>
