Author: Subject: Is anyone using an electric line lock / roll control system?
TimC
posted on 11/11/17 at 09:55 PM Reply With Quote
Quite simply, does the solenoid make a noise when energised?
Mine doesn’t and this worries me.
posted on 12/11/17 at 12:53 PM Reply With Quote
I've been looking at the Hurst one with the thought of using it as a handbrake for the very few hill-starts that I'll be doing.
Clearly not what it's designed for, and it's not a road legal handbrake, but it would make for a really neat install.
It's Evolution Baby!
TimC
posted on 12/11/17 at 04:33 PM Reply With Quote
Yes that’s what I’ve installed - in theory for slightly sloping grid starts. I just wish that I knew it was working. Obviously I’ll find out when I fill the brake system but it would be nice to know that all is okay now.
posted on 12/11/17 at 09:31 PM Reply With Quote
They're common in the States, and considered to be fairly robust bits of kit.
Oddified
posted on 12/11/17 at 11:38 PM Reply With Quote
I have the Hurst one fitted on my Kitten for a line lock doing drag racing. I have it connected up so- apply brakes in burn out area, press push button, release brakes but front remains locked, spin up/smoke, release button unlocks front and roll/power out of burn out to line.
Works very very well. There's no audible click on operation that i've ever heard.
Ian
[Edited on 12/11/17 by Oddified]
Kdempsie
posted on 13/11/17 at 07:46 AM Reply With Quote
It's usually possible to check if the solenoid is work (electrically at least) by energising it off and on holding a small screwdriver at the top of it, you will feel the screw driver pulled towards it at the coil is switched on.
posted on 13/11/17 at 10:11 AM Reply With Quote
Did you get the 'on' LED with your kit... I know it's not a fail-safe, but handy nonetheless.
TimC
posted on 13/11/17 at 11:49 AM Reply With Quote
I’ve checked continuity and can see a change in resistance when on so I guess all is well.
Thanks, as ever, for the input.
TC
