Author: Subject: Haynes suspension - probably 2x stupid questions!!
jps
posted on 13/11/17 at 08:50 PM Reply With Quote
Sorry for the stupid questions, I feel sure I know the answers but am asking out of caution...
'The book' states the builder should use dampers that are 13" open / 9" closed, with a 25mm extension.
Question 1 - I assume this is the same as 14" open /10" closed?
Question 2 - Can I mock up the maximum extents of movement in the suspension using 2 lengths of box section, one with 10" between the holes for the bolts (for 'most compressed' ) and one with 14" between the holes (for 'least compressed' ) ?
[Edited on 13/11/17 by jps]
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 13/11/17 at 09:36 PM Reply With Quote
Hi JPS,
Good to hear from you!
Perhaps you missed this tread on the Haynes forum?
http://forums.haynes.co.uk/showthread.php?t=7246
To summarize and answer your questions:
Question1:
For a "book design" car (Sierra based), shocks should be 14'' open (or 13''+1'' extension), but still 9'' closed. But when it comes to Gaz Shocks, the 14'' open shocks come in 9.5'' closed only. That is what I have on my car. Body diam=2''.
Question2:
For your mock up, you can take a 14'' box section for the long ones, and either 9'' or 9.5'' for the short ones, according to what shock brand you are going to buy.
Springs should be 8'' long (2.5'' diam), different rates should be tried, even-though 350lb front and 250lb rear seems to be a good start (it worked for me that, is what I have on my car)
Hope the will help
555
big_wasa
posted on 13/11/17 at 09:39 PM Reply With Quote
The extension may be for the spring seat to clear the chassis ? It was very close on a Locost.
[Edited on 13/11/17 by big_wasa]
ianhurley20
posted on 13/11/17 at 11:36 PM Reply With Quote
Similar to Sylvain - I have Gaz 14" x 9.5" shocks with 350lb front springs and at the moment 250lb rears but am changing the rears to 300lb this winter as I am often travelling two up with probably 30 stone of passengers on board, I am not sure if this will be my final set of springs but if I was solo then the 250lb ones would be the ones I would go for.
jps
posted on 14/11/17 at 04:21 PM Reply With Quote
Originally posted by voucht
Hi JPS,
Question1:
Question2:
Hope the will help
Cheers Sylvain - yes, still very slowly plugging away at my build!!! Thanks for the pointer to the Haynes forum, your summary is helpful! I am just mocking up the max/min movements of the front suspension so I can cut the right holes in my side panels... (yes - still on that job...!)
craigdiver
posted on 14/11/17 at 06:22 PM Reply With Quote
I am using the following after much research (and recommendations from other users and forums);
From rallydesign;
4 x Gaz 14" Open, 9.5" Closed Length Coilover Shock (140/095/B12-2)
2 x 2 1/4", 400 Rate, 8" Free Length (RD1195/8)
2 x 2 1/4", 250 Rate, 9" Free Length (RD1189/9)
1 x C Spanner - Coil Over Spring Seat Adjuster (2 1/4" (RD207)
Please note I have a straight 6 BMW lump under the bonnet hence the 400lb springs up front. Car not road tested yet so springs may be changed.
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
procomp
posted on 14/11/17 at 08:02 PM Reply With Quote
Hi.
Just for conformation, what i supply for book roadster chassis is 14" open 9 1/2" closed.
The reason for the 13" + 1" was an attempt by author and designer to only allow one make off damper to be supplied / used. This can be ignored and just use 14" open units.
Cheers Matt
ianhurley20
posted on 14/11/17 at 08:10 PM Reply With Quote
Originally posted by procomp
Hi.
Cheers Matt
Thanks for that Matt - it explains a lot
jps
posted on 15/11/17 at 05:47 PM Reply With Quote
Hi.
Cheers Matt
Yes- thanks for that, it is useful to understand the why behind stuff!
