Author: Subject: Sierra ignition barrel
johnnybizzle1986
posted on 30/11/17 at 01:54 PM Reply With Quote
Hi Guys,
I dont have a key with my sierra steering column, is there a way of removing the barrel so that I can install a new one
Regards Jon
posted on 30/11/17 at 02:05 PM Reply With Quote
Don't know, but what about one of these...
Daf
posted on 30/11/17 at 02:24 PM Reply With Quote
Originally posted by johnnybizzle1986
Hi Guys,
Regards Jon
Yes... but you need the key to do it!
http://www.fordmanuals.org/page-1684.html
You might be able to achieve the same thing by hammering a big screwdriver in and turning it to position 1 - but I don't know what else would get trashed in the process.
madteg
posted on 30/11/17 at 02:33 PM Reply With Quote
I drilled mine out but its a right pain in the ar-e
chris
posted on 30/11/17 at 04:41 PM Reply With Quote
arent the seirra barrels just clamped to the column and wiring three wires or four
i got a new ignition barrel from CBS and mounted it to dashboard
ian locostzx9rc2
posted on 30/11/17 at 05:43 PM Reply With Quote
Theres a little pin you need to drill out then you can release the lock barrel from the holder .
johnnybizzle1986
posted on 30/11/17 at 08:38 PM Reply With Quote
Ok
Thanks guys il give it a whirl this weekend
Regards
ianhurley20
posted on 30/11/17 at 11:05 PM Reply With Quote
Forgive me but I seem to remember being told that if i screwed in the threaded end of a slide hammer then slid the weight back I only needed a screwdriver to start and drive the car - or maybe that was several years ago
posted on 1/12/17 at 04:58 PM Reply With Quote
You may find any Ford key of the type Sierras used might allow you to remove the barrel ?
