Author: Subject: Wishbone front lower
Minicooper
posted on 5/12/17 at 08:28 PM Reply With Quote
Hello all,
Does anyone know what the dimension is between the centre of the bush to the centre of the hole for the ball joint, as they look the longest of the locost style cars I'm seeing if a standard wishbone will do the job on my project. I would rather buy them than make them.
I may consider the westfield wide wishbones as sold by rally design if any one knows there dimensions
Myke 2463
posted on 6/12/17 at 11:40 AM Reply With Quote
Locost book 340mm Haynes book 412mm
Be Lucky Mike.
Minicooper
posted on 6/12/17 at 01:53 PM Reply With Quote
Thanks Mike
craigdiver
posted on 7/12/17 at 12:14 PM Reply With Quote
Had the same problem myself, wanted to buy the haynes roadster wishbones but struggled to source them. Eventually bought some used ones and reconditioned them.
Someone must have made these professionaly but I suspect gave up selling them due to lack of demand.
good luck ;-)
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Abarth 595
Classic Fiat 126 aircooled
Aprilia Mana 850
Kia Picanto
Mopple
posted on 7/12/17 at 01:42 PM Reply With Quote
Batho Sportscars seems to sell book specification suspension components for Haynes Roadster http://bathoscars.simpl.com/shop.html.
nero1701
posted on 8/12/17 at 07:32 PM Reply With Quote
ive a full set of front and rear Haynes/saturn arms in the garage, they are also poly bushed. surface rust as the spray paint was crap.
75 collected if you want them? or swap me something I can use on my gbs build
Minicooper
posted on 9/12/17 at 01:27 PM Reply With Quote
