Author: Subject: Autotune Gemini 4C8 R1 First start.
TimC
posted on 10/12/17 at 08:45 PM Reply With Quote
YouTube Link - if itís not on camera, it never happened, right?
The faffing at the start of the video is me ensuring that the extinguisher is ready.
I am a smidge effing delighted.
[Edited on 10/12/17 by TimC]
andy188
posted on 10/12/17 at 09:20 PM Reply With Quote
sounds sweet, b carefull with them fumes.
Camber Dave
posted on 11/12/17 at 09:00 AM Reply With Quote
Just a few seconds after many hundreds of hours of work,
But it means everything, I reckon.
Congratulations Tim
TimC
posted on 11/12/17 at 10:09 AM Reply With Quote
Congratulations Tim
Thanks Dave. It makes a big difference. Iíve got a new trailer on order too so I will definitely be across to see you in the new year for suspension set-up etc.
Kev99
posted on 11/12/17 at 11:41 AM Reply With Quote
Great Feeling that is Tim getting it started for the first time
Its a great little engine the 4C8 but do not forget to baffle plate it and do the rocker cover mods
Mines been in about 4 to 5 years and has taken a lot of abuse and still keeps giving
Kev...
TimC
posted on 11/12/17 at 12:00 PM Reply With Quote
Originally posted by Kev99
Great Feeling that is Tim... do not forget to baffle plate it and do the rocker cover mods
All done! Great to hear about your reliability.
adithorp
posted on 11/12/17 at 12:08 PM Reply With Quote
Don't think I could have avoided the temptation for so long though.
http://jpsc.org.uk/forum/
TimC
posted on 11/12/17 at 01:52 PM Reply With Quote
I had intended to do it a couple of weeks ago but when I added the coolant I literally filled the engine - the o-ring on the water pipe that goes into the water/oil pump had failed and the sump filled with expensive coolant. I was not happy and had to drain everything, replace the o-ring, sump gasket blah blah...
But then, you werenít talking about starting the engine just two weeksí ago...
CosKev3
posted on 11/12/17 at 03:15 PM Reply With Quote
Sounds well
That garage is way too clean though!
emlyno
posted on 11/12/17 at 07:29 PM Reply With Quote
Congratulations Tim, it's been a long journey but you're getting there.
TimC
posted on 16/12/17 at 03:05 PM Reply With Quote
And it now moves...
Not without issue however: Digidash doesnít like RPM signal and my rad is pretty useless.
Still, winning overall - very happy with clutch feel in particular.
daniel mason
posted on 16/12/17 at 05:26 PM Reply With Quote
Have you tried running the tacho from the coil pack?
Car looks nice btw
adithorp
posted on 16/12/17 at 06:14 PM Reply With Quote
Nice
Whats the issue with the rad'?
TimC
posted on 16/12/17 at 06:46 PM Reply With Quote
Well, sat for 15ish minutes at 6deg ambient and it was up-at 100deg. Firstly, some plonker didnít think a fan would be necessary. Secondly itís an ancient Serck unit that probably isnít as good as it should be. I am however a bit scared by the cost of new custom rads. Oh well.
What temp will yours sit at Adi? I should say that my oil temp is yet to go above 60-odd deg.
adithorp
posted on 16/12/17 at 07:10 PM Reply With Quote
I wouldn't worry about it then. On mine without the manual fan switch on or any airflow it'll go all the way to the ECU fan switch on at 105c. Won't take too long either. Once warmed up/run it will rise rapidly once stationary so I'd say you def' want a fan.
TimC
posted on 16/12/17 at 08:54 PM Reply With Quote
Interesting- I might throw a fan on it and see what happens.
Mike Wood
posted on 17/12/17 at 12:27 PM Reply With Quote
Tim
Great to see your Autotune Gemini starting and moving. Racing in 2018?
What's happened to all your various car build blogs?
Mike
TimC
posted on 17/12/17 at 07:33 PM Reply With Quote
Originally posted by Mike Wood
Tim
Mike
Hi Mike,
Iím hoping to do something with the CSCC Open Series and/or Welsh Saloons and Sports.
Life has sort-of got in the way of blogging - that and Google deciding to no longer offer an interface for iOS.
I do have an unpublished update somewhere which I penned on holiday - might see if I can do something with that.
