Author: Subject: Chain drive diff offset
Stirls
posted on 16/12/17 at 09:01 AM Reply With Quote
I am duilding bike engine single seat car.
The diff is a converted mX5 one to chain drive. When lined up behind the engine itís not central.
The diff type is the old one that the drive shafts bolt on.
Question is would it be ok machining a spacer to mate up the difference. Of get a longer drive shaft on one side?
daniel mason
posted on 16/12/17 at 11:22 AM Reply With Quote
If the engines central to the chassis then the front sprocket will be way off centre,like most single seaters.
Unequal driveshafts is perfectly normal assuming he diffs not too low in the chassis making the angle of the short shaft too steep!
Mike Wood
posted on 17/12/17 at 07:40 AM Reply With Quote
You may want to talk to Doug at West Garage for advice and parts related to chain driven diffs: http://www.westgarage.co.uk/services/chain/chaindrives.html
Best wishes
Mike
Guess you have seen Tony Pashley's book on building biked engined single seaters: https://www.amazon.co.uk/How-Build-Motorcycle-engined-Racing-Cars/dp/1787111695 as well as Allan Staniforth's very useful 'Race and Rally Car Source Book': https://www.amazon.co.uk/Source-Anniversary-building-modifying-competition/dp/0857333488/ref=sr_1_1?ie=UTF8&qid=1513496750&sr=8-1&keywords =Race+and+rally+car+sourcebook (NB cheaper earlier editions available too)
[Edited on 17/12/17 by Mike Wood]
Stirls
posted on 17/12/17 at 12:53 PM Reply With Quote
Thanks Mike
I have already been emailing them about the diff and just waiting on a reply for this question.
Best wishes
Mike
