Author: Subject: ST170 Exhaust Valves
Barksavon
posted on 2/1/18 at 11:14 PM Reply With Quote
I am refurbing the cylinder head on the ST170 engine that is going in my Tiger and have taken the valves out. All the exhaust valves have a 'build up' of an off white substance on the valve face and back of the valve which extends about an inch up the stem.
Does anyone know whether this is a result of the combustion process or some sort of coating deliberately applied....don't want to wire brush it off if it should be there.
Ian
ian locostzx9rc2
posted on 3/1/18 at 06:51 AM Reply With Quote
Sounds like it just carbon build up just clean them put them in a drill slow speed get some wet and dry paper / sand paper and clean them advise you to wear a
Mask
