Author: Subject: Short diff
hp600x
posted on 19/1/18 at 01:08 PM Reply With Quote
Short diff
Hi guys, I am looking for a diff, for my r1 powered Fiat 600
I have limited space, the engine is mounted at the rear, with the drive pointing at the front.
My plan is to use a rwd diff, turned upside down.
Witch, readily awailable diff is the shortest ?
Ford 7 inch, Freelander , BMW or other ?
A lsd is a given, so it needs to have that awailable.
HP
Doctor Derek Doctors
posted on 19/1/18 at 02:27 PM Reply With Quote
The MX5 different seems to be quite short from flange face to outputs.
Designer and Supplier of the T89 Designs - Single Seater Locost. Build you own Single Seater Racecar for ~5k.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
ReMan
posted on 20/1/18 at 09:50 AM Reply With Quote
Quick look on eBay and I thought MX5 too.
Ignoring the power capeability I wonder what one off a small 4x4 would be like for instance a Panda?
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
fregis
posted on 21/1/18 at 11:33 AM Reply With Quote
ford sierra 4x4 front diff short, because is front you dont need put up side down. but i dont know power it can handle.
Also you can look others front diffs, some cars have smalls diff like this
https://www.ebay.com/itm/1990-Suzuki-Quadrunner-250-King-Quad-300-Good-Front-Differential-Diff-Final-Gear-/401130179069
[Edited on 21/1/18 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
hp600x
posted on 21/1/18 at 02:25 PM Reply With Quote
Thank for the help guys
I have found a few VW front diffs, that look good, will order one and see.
HP
