Author: Subject: Silvertop Zetec inlet manifold parts
alistairolsen
posted on 22/1/18 at 10:21 AM Reply With Quote
I'm looking for some parts from a standard silvertop zetec which hopefully someone has laying about after converting to carbs/throttle bodies.
I need the bolts which hold the factory fuel rail to the plastic inlet, and also the seals which go between the fuel rail and the plastic inlet.
If someone has a whole engine, I could also do with the heatshield which goes over the OEM exhaust manifold and the bobbins that go in the cam cover recesses around the bolts.
Alistair
My Build Thread
