Author: Subject: Clutch slave
davew823
posted on 24/1/18 at 12:03 PM Reply With Quote
Clutch slave
It sounds like all you need is just a slight increase in volume. You can try repositioning the master cylinder push rod on the clutch pedal. Probably would only require small adjustment to increase the stroke. You do not want to angle the M/C push rod more than 7* which will lead to a side load and higher wear or possible blinding. If that is not an option than you have to go up the next size M/C. dave w
