Author: Subject: Brake test switch wiring
CTLeeds
posted on 28/1/18 at 11:05 AM Reply With Quote
Hi all,
I've wired the whole of my Rush successfully apart from the following...
I bought one of these... https://www.carbuildersolutions.com/uk/iva-rocker-switch-brake-warning-and-test. Does anyone have a wiring diagram for it? It doesn't seem to want to light even if I connect the illumination contacts directly to a battery with the switch in the on or off position, I'm a bit baffled to be honest. I'm sure I'm missing something?
Any help appreciated.
Chris
ReMan
posted on 28/1/18 at 11:15 AM Reply With Quote
Does it light if you put the power across the lamp terminals? {the spades I believe}
Edited to say, I think you’ve already said that it doesn’t, in which case it’s faulty
[Edited on 28/1/18 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
CosKev3
posted on 28/1/18 at 12:41 PM Reply With Quote
Yeah it must be faulty, if it's only got two terminals on rear and you've put power straight to it?
CosKev3
posted on 28/1/18 at 12:45 PM Reply With Quote
Ah it's got 4 connections,and is back lit.
Is there no ID markings near the terminals?
CTLeeds
posted on 28/1/18 at 01:30 PM Reply With Quote
That's what I thought, so I destroyed the first one I bought trying to work out how it worked. I bought a second and that doesn't work either do unless there's a dodgy batch I'm doing something wrong.
gremlin1234
posted on 28/1/18 at 01:50 PM Reply With Quote
this page should help
http://www.theminiforum.co.uk/forums/topic/117159-brake-test-switch/
essentially the lamp is between the spades, and the switch the pins on the back
CTLeeds
posted on 28/1/18 at 02:40 PM Reply With Quote
Thanks for your replies chaps. Gremlin, thanks for this, it will hopefully sort it out.
mcerd1
posted on 29/1/18 at 09:39 AM Reply With Quote
do you really need the test switch ?
I always thought it was sufficient to use the handbrake switch to activate the low fluid warning light - that way your handbrake is your 'test facility'
and all you need on the dash is a single warning light for all 3 functions (i.e. handbrake, low fluid and brake failure)
Even my old 90's tin-tops used this setup (pre CAN bus) - simple and cheap with no extra switches required
(see note 3 in section 09D of the IVA manual)
[Edited on 29/1/2018 by mcerd1]
