New Topic New Reply
Author: Subject: MK INDY R frame - Zetec and Type 9
Daz1234
posted on 28/1/18 at 06:28 PM Reply With Quote
Hi again
Is anyone on here actually running a Indy R, Zetec and Type 9?
If so please can you let me know - I have a range of head scratching questions that i'm sure can be easily answered by someone running the same setup as me!
Be very grateful!
Daz
Slater
posted on 28/1/18 at 08:11 PM Reply With Quote
I am running MAC#1 Type ZR, Zetec and Type 9
I believe the MAC#1 is "similar" to MK Indy.
Its a common combination, ask away......
Daz1234
posted on 28/1/18 at 08:35 PM Reply With Quote
Hi thanks for the reply.
First one is that my gear lever sits about 4" below the tunnel top. Which seems odd - cant really be anywhere else though as the engine/gearbox position is determined by the mounts etc.
Just wondering how people are managing that?
Ill have to have a huge hole in the tunnel top to allow the movement or the gear level?
Daz
Slater
posted on 28/1/18 at 10:10 PM Reply With Quote
See pics from my build.
[img] engine in 037
engine in 037
[/img]
[img] engine in 032 x
engine in 032 x
[/img]
looking at my pics the gear lever mounting surface is about 4" below tunnel top. I chopped a few inches off the top of sierra lever and it fits just fine. There is enough room to select all the gears.
NOTE: The MAC#1 engine mounts are quite far back in the car so the lever is in the correct place ergonomically, not under the dash like some other sevens where you need an extension.
[img] 10Aug08 021
10Aug08 021
[/img]
[img] DSC04061 gearbox
DSC04061 gearbox
[/img]
[Edited on 28-1-18 by Slater]
Daz1234
posted on 28/1/18 at 10:58 PM Reply With Quote
If the lever of that far below the tunnel top. The travel by the tunnel top if far greater. So surely you end up with a massive hole (instead of a small one)?
Daz
CosKev3
posted on 28/1/18 at 11:21 PM Reply With Quote
Mac1 ZR is similar to the old Indy with box section chassis, but the newer Indy R is a round tube chassis with inboard shocks on the front,totally new chassis compared to the box section Indy
Daz1234
posted on 29/1/18 at 07:56 AM Reply With Quote
Yeah really I need indyr zetec owners. There must be some??
Daz
Slater
posted on 29/1/18 at 10:51 AM Reply With Quote
Here is my "hole", it's not massive. The pivot point for the type 9 gear lever is actually above the mounting plate, about 1-2" from memory. So the throw at tunnel top is fine and certainly does not touch my square MAC#1 chassis members.
I had to shave a bit off the right angle ali trim to get reverse, but that's only because the gearbox sits slightly to the left in the tunnel.
[img] dash post sva 2
dash post sva 2
[/img]
Daz1234
posted on 29/1/18 at 10:57 AM Reply With Quote
Thanks for the reply. ok... in my book thats massive!
Hopefully some MK guys can share there pics too.
Thanks again
Daz
Angel Acevedo
posted on 29/1/18 at 03:28 PM Reply With Quote
Daz
Could you not modify the ratio on the lever?
This is accomplished extending the distance between the fulcrum and the end that actuates the forks inside the transmission and fabricating and installing a shim between the cover and transmission. This shim must be the same thickness as the added distance on the lever.
All this results in a shorter throw.
On the other hand a big hole in the transmission tunnel is some "Lightness" added for free... Unless gaiter leather and mounting hardware is more than removed metal.
HTH
New Topic New Reply
