Author: Subject: Wheel clearance
Shooter63
posted on 10/2/18 at 09:35 AM Reply With Quote
Wheel clearance
I've been looking for some 13" wheels with a half decent offset without any success so I think I'll have to bite the bullet and order up some new ones, not sure which yet but probably revolutions, image, force etc while I know how to work out the offsets etc what I need to know is how much clearance should I allow, I'm thinking 10mm would be ok, what are people's thoughts
Shooter
steve m
posted on 10/2/18 at 10:09 AM Reply With Quote
I have 1mm clearance between the inner wheel weight and the brake caliper, never had an issue yet
steve
[Edited on 10/2/18 by steve m]
Shooter63
posted on 10/2/18 at 10:42 AM Reply With Quote
Thanks but I'm really talking about the clearance to the suspension arms on the rear axle
Shooter
CosKev3
posted on 10/2/18 at 12:55 PM Reply With Quote
Shooter
Perhaps you should have said that in the opening post then!!!!!
Lots of Westfields with wide 13 inch rims on the rear run a few mm''s of clearance to the bottom hub mounting bolts without issue,I think you can reduce your 10mm to 5mm with ease imo
