<<  1    2    3    4  >>
Author: Subject: IVA preperation pictures...
furryeggs
posted on 13/2/18 at 09:06 PM Reply With Quote
My IVA paperworks now gone off and hopefully with the right people. I've tried calling but the women said she couldn't check the system because it was monday? so I'll have to try again at the end of the week. Great start...
There will be a lot of pictures over the next week or two so please feel free to comment.
Rear light's fitted and clipped in place...
[img][/img]
I do need to bond the bases onto the wings, at the minute they are just stuck with pads...
[img][/img]
Indicator extensions, these bring them out to pretty much bang on 40cm from the widest part. (the rear arches)
[img][/img]
Edge trim around the filter cut out and bonnet catches... the catches were supplied by tiger and I was told they pass without covers???
[img][/img]
More edging around the bonnet cut out and airo-screen...
[img][/img]
Trim on the rear lights...
[img][/img]
Hopefully my spacings and hights are ok, they should be as I'm well over the minimum required hieghts...
[img][/img]
Tow strap fitted with a 12.9 bolts, I've held it up out of the way with a cable tie, is this ok?..
[img][/img]
Seat edging and harnesses...
[img][/img]
Seat belt mounts and caps...
[img][/img]
Handbrake adjustment...
[img][/img]
Tunnel wiring, the main loom is clipped in place with a loom tape wrapped wire for my fuel pump switch cable tied to it. Is this going to need further wrapping?...
[img][/img]
My ignition barrel is exposed, what can i cover this with? I was thinking maybe a rubber cap or something...
[img][/img]
Engine bay...
[img][/img]
Fuel line...
[img][/img]
Fuel pipe markings...
[img][/img]
Battery and cabling...
[img][/img]
All advise is appreciated.
Andybarbet
posted on 13/2/18 at 09:14 PM Reply With Quote
Looks really tidy, gives me something to aim for on my build - good luck with the IVA
CosKev3
posted on 13/2/18 at 09:17 PM Reply With Quote
Looks tidy
I think I would leave the tow strap off for IVA,as it's not required.
Is your rear fog light vertical?
Also I'm not sure on the bonnet catches,what are the radius on them?
[Edited on 13/2/18 by CosKev3]
craigdiver
posted on 13/2/18 at 09:18 PM Reply With Quote
Car looks fantastic, canít advise on much but I have been advised by my glassfibre guy that the nylon cable tie bases can be stuck on very securely with a hot glue gun. Also, iím looking for exactly the things with two allen grub screws for locking the handbrake cables that you have, where did you get them?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Abarth 595
Classic Fiat Panda 1000 CLX
Aprilia Mana 850
furryeggs
posted on 13/2/18 at 09:43 PM Reply With Quote
I think I have 2spare in my box, Iíll check tomorrow.
furryeggs
posted on 13/2/18 at 09:56 PM Reply With Quote
Originally posted by CosKev3
Looks tidy
- Iíll remove the strap...
- Think I might put some foam/rubber under the top edge of the fog to bring it closer to verticle, Itís not far off at the minute.
- The catches are radiused along the main body, but bits of the definitely arenít rounded. Iím going to try and find a cover for them.
CTLeeds
posted on 13/2/18 at 10:05 PM Reply With Quote
I'm at pretty much the same stage as you. Yours looks very smart.
I think I'd use some proper pipe clips rather than cable ties on the fuel pipe. The pipes could be seen as rubbing together?
As long as your ignition terminals are properly insulated then there shouldn't be a problem(don't quote me on that though). I'd suggest unsoldering the wires, put a couple of layers of heat shrink up each of the cables, resolder, put heatshrink in place etc.
Where are your side repeaters located?
Chris
kingster996
posted on 13/2/18 at 10:50 PM Reply With Quote
Looks good.
Check that the harnesses are horizontal between where they bolt in and the seat slots. They canít be lower at the bolts so as to pull down on seats under tension.
Otherwise, as said, forget the tow strap, just in case.
I used to be indecisive, but now I'm not so sure
loggyboy
posted on 13/2/18 at 11:27 PM Reply With Quote
Looks very neat.
Mirror above coments on:
-fog (get it bang on square, not just close)
-seatbelts, ensure they aren't pulling on edges of seat.
-bonnet catches. Dont rely on suppliers, be happy/safe that they are right.
Any pictures of front end?
CosKev3
posted on 14/2/18 at 09:11 AM Reply With Quote
Originally posted by kingster996
Looks good.
Oh yeah the harnesses are definitely a failure.
Looks like you will need some longer bolts and spacers to lift them ,if this is allowed?
Or the seats need to be lowered.
And as above,the fog HAS to be vertical
furryeggs
posted on 14/2/18 at 09:53 AM Reply With Quote
Looks good.
Canít drop the seats any lower as they are all ready bolted directly to the floor rails. Iíll make some spacers at work.
CTLeeds
posted on 14/2/18 at 11:37 AM Reply With Quote
With regards to the rear fog light, the manual states...
"9. Fitted so that the reflector is facing squarely to the rear". In my mind this means you can't have it angled to the left or right relative to the rear of the car. Do they also check that it's vertical relative to the floor? The wording is a bit ambiguous in my opinion and currently mine is not vertical. it's square but not vertical... Hmmm
loggyboy
posted on 14/2/18 at 11:53 AM Reply With Quote
Not ambiguous at all, Square is square! Its in 2 planes, both viewing from above and side. It needs to be at 90degrees to ground when looking from side and is a common failure.
CTLeeds
posted on 14/2/18 at 12:01 PM Reply With Quote
Okay, thanks. That clears that up. I'd better work out a way to make it "square" in two planes. I might just ramp up my front springs and lower the rear for the test...
Bunje
posted on 14/2/18 at 12:41 PM Reply With Quote
your car looks great. can i ask where you got the bonnet vents from
furryeggs
posted on 14/2/18 at 01:35 PM Reply With Quote
A pen, a ruler and a dremil ... I cut a hole in the bonnet and bonded a piece of grill mesh behind it. cost about £3
cheers
Bunje
posted on 14/2/18 at 01:50 PM Reply With Quote
where did you buy the grill mesh from looks exactly what im looking for
Christof
posted on 14/2/18 at 02:37 PM Reply With Quote
I'd say if in doubt, take a back up plan. They'll probably let you tweak a few things.
milliput, sugru, bits of rubber - always useful
as for sharp edges, find a ball that gives you the correct radius etc
if you fail you will at least have a definitive list of items to remedy at a modest additional cost relative to the initial fee
furryeggs
posted on 14/2/18 at 02:41 PM Reply With Quote
Just spoken to the DVLA and they have now recieved my paperwork and are currently working their way trough the application...
posted on 14/2/18 at 03:46 PM Reply With Quote
Looking at the first picture - I nearly failed my SVA because of those cable tie bases. They WILL look at those with a suspicious eye and you have to prove that your fixing method is up to the task, otherwise they'll fail them out of hand. They might just fail them anyway, out of habit...
Luckily I was able to tie the cables to a couple of chassis tubes.
The older I get, the better I was...
furryeggs
posted on 14/2/18 at 04:57 PM Reply With Quote
Iíve not got anything to tie them to. Iím not drilling holes in my wings to secure them... Iíll epoxy them to the underside and hope for the best.
Surely at some point ďwhere practicableĒ will have to be incorporated into the IVA???
zx12r dug
posted on 14/2/18 at 05:48 PM Reply With Quote
Hi I can't see really from the picture inside of your rear arch if there are any threads sticking through the nylock nuts holding your lights on but looks like there's plenty of thread on the reverse light tester might not pick up on but you might get a fussy one.Wiring looks neat but would of looked much neater in conduit.Good luck on your test be on the road just in time for the better weather
ttalps2000
posted on 14/2/18 at 06:04 PM Reply With Quote
i failed on ALL of the indicator NOT being in the 400mm limit from the widest point. However on my retest they measured nothing and was a different inspector with a completely different attitude!
The seat belts through the seats - i never put any trim in mine and they never mentioned it at all
Good luck on the test, it looks very well built and they like that and will be less harsh!
craigdiver
posted on 14/2/18 at 07:16 PM Reply With Quote
Sorry for being a pain, did you get a chance to see if you had any or remember where you got them?
Craig
Abarth 595
Aprilia Mana 850
Irony
posted on 14/2/18 at 09:13 PM Reply With Quote
Bonnet catches - I think will fail the radius test
Bolts hold roll cage - radius test
Where is your ID plate thingy.
Where is your vin stamped. How is it stamped.
Show us the dash, and the front suspension.
Looks really tidy!!
<<  1    2    3    4  >>
