Author: Subject: Savage switch dim/bright
gaz_gaz
posted on 22/2/18 at 11:23 AM Reply With Quote
Has anyone here done the savage switch dim/bright wiring?
Looking for someone to do the wiring for me. Can send the dash and buttons and obviously pay you for the work?
ttalps2000
posted on 22/2/18 at 12:28 PM Reply With Quote
if you get a FOC result on this then I would be interested!
loggyboy
posted on 22/2/18 at 12:43 PM Reply With Quote
Assuming you want them to dim with the lights going on so they are less bright at night?
I would assume they have a separate connection to the illumination? If so will simply be matter of wiring a circuit that's triggered by the lights being on to switch the illumination to a resisted circuit. You could even wire a potentiometer so that you can adjust the brightness.
Mistral Motorsport
gaz_gaz
posted on 22/2/18 at 12:59 PM Reply With Quote
what's a FOC result?
loggyboy
posted on 22/2/18 at 01:05 PM Reply With Quote
free of charge
Mistral Motorsport
gaz_gaz
posted on 22/2/18 at 01:06 PM Reply With Quote
I'd like them to work as follows
day time - LEDs all off until switch is pressed then only that switch illuminates.
night time - Pressing sidelights switch turns sidelight LED to full bright and all other switches to dim. then when each switch is pressed that LED goes full bright.
hopefully that makes sense
gaz_gaz
posted on 22/2/18 at 01:13 PM Reply With Quote
free of charge
I thought as much but not sure why anyone would want to do it for free. seems like quite alot of fiddly work to me.
Russell
posted on 22/2/18 at 04:15 PM Reply With Quote
I've got a solution for this, just needs diodes and resistors so it's not free but is very low cost. I'll dig out the circuit.
ttalps2000
posted on 22/2/18 at 04:43 PM Reply With Quote
i meant it as in if the solution is posted on here, rather than paying someone to do it for you and not knowing how it was done
rdodger
posted on 22/2/18 at 06:36 PM Reply With Quote
CBS used to sell a resistor with some tails on it to do this.
I did it as already mentioned with a few resistors and diodes. All I can remember is it was easier with the dbl pole connection blocks.
Here it is
https://www.carbuildersolutions.com/de/dimbright-wiring-kit-for-billet-aluminium-switches
I'm no electrical engineer but I think you would still need to add a diode. I certainly did on the hazard switch.
[Edited on 22/2/18 by rdodger]
rodgling
posted on 22/2/18 at 06:47 PM Reply With Quote
I did this on mine, when dipped beam is on they light up dimly, but each individual switch lights brightly when on. It's straight-forward, just use a resistor to get the dim effect, with a few diodes to help manage the switching. I may even have a scribbled diagram on the back of an envelope which I will post here if I can find it.
Russell
posted on 22/2/18 at 08:09 PM Reply With Quote
Link to wiring diagram
I'm a bilingual illiterate. I can't read in two languages.
